Trail gear spacer lift
Discussion in 'Suspension' started by kperickson, Oct 17, 2013.
  1. Oct 17, 2013 at 8:10 AM
    kperickson
    kperickson [OP] Well-Known Member
    Secret Town
    07 SW DCLB
    For the time being was looking to get the trail gear spacer lift. Was wondering if anybody has had any issues with the kit. Thanks for any info.
  2. Oct 17, 2013 at 8:21 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Its a piece of aluminum that pushes your strut assembly down giving you lift, not much to talk about and brand doesn't matter.
  3. Oct 17, 2013 at 8:23 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I have a toytech leveling kit that came with spacers and it made the ride rougher than hell. When i go over speed bumps no matter what speed it feels like I have 0 travel what so ever up front. I have a 3'' spacer and AAL
  4. Oct 17, 2013 at 8:33 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Spacer dimensions might help :)
  5. Oct 17, 2013 at 10:03 AM
    kperickson
    Secret Town
    07 SW DCLB
    This is straight from their website.
    TACOMA COMPLETE FRONT & REAR 3" LIFT
    Looking for a complete kit for better ground clearance on your Tacoma? Trail-Gear is now offering a Tacoma Complete Front & Rear Lift for the Toyota Tacoma 2005-2013 Prerunner/4WD. This lift kit includes our Tacoma Front Spacer Lift, 3” , Tacoma Rear Add-A-Leaf 2”, and our Tacoma/FJ Cruiser Differential Drop Kit. The Tacoma Front Spacer Lifts are made from CNC-machined 6061-T6 aircraft grade aluminum and are anodized orange to prevent corrosion. The Tacoma Front Spacer Lift includes Class 10.9 bolts for the top spacer. Our Tacoma Front Spacer Lift will work with stock shocks and many other shocks and will add 3” of lift in the front, levels the truck, and eliminates the factory rake.
    Our Tacoma Rear Add-A-Leaf comes includes plastic anti-friction pads installed and two zinc-plated leaf spring center pin bolts. Our Tacoma/FJ Front Differential Drop Kit is made out of solid aircraft-grade 6061-T6 aluminum and zinc-plated Grade 8 hardware. The complete lift will also include our new Tacoma Driveline Spacer Kit. The Tacoma Driveline Spacer Kit is made out of 5/16” thick zinc-plated steel. Longer M10 mounting bolts are included in the driveline spacer kit.
  6. Oct 18, 2013 at 7:36 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Sounds like they are including stuff not needed. For one spacers are the least desirable way to lift and for good reason. The 2" add a leaf doesn't really make sense because you won't be level. The diff drop, well this is just a toss in so they can charge more $$$ for the kit. As for the drive line spacer, this is not really needed either but they’ll attempt to justify the use of it with the 2” AAL which should be a 1.5 AAL instead to level you.
    BTY this is to say nothing bad about the comp, I'm just offering my opinion.
  7. Oct 18, 2013 at 9:57 AM
    kperickson
    Secret Town
    07 SW DCLB
    appreciatethe feedback. obviously new to the tacoma world. On a tight budget unfortunately. Is there a better option that doesnt cause a fortune.
  8. Oct 18, 2013 at 10:11 AM
    IronPig
    IronPig Well-Known Member
    CA
    08 PreRunner DC
    Toytech Ultimate Lift Kit, LR UCA's, T3 eyelids, 285/75/16 Nitto Terra Grapplers, FN Type X wheels, Debadged, Homer Taco Raptor Grill and lower valance grill, painted lower valance, blacked out skid plate, Flyze Eye interior light, LED interior lights, EZ down tailgate
    You should do a lot of research on this site before you buy. You will find that 99% of people will tell you NOT to buy a spacer lift. They are cheap for a reason. Look around this site and most will say to look at Toytec.com and other sites. As far as lifts go, there are happy people with OME Lifts ($700) and some that spend less and go for Bilstien shocks all around for a little over $300. Look around this site though, there is a TON of info!!
  9. Oct 18, 2013 at 10:21 AM
    kperickson
    Secret Town
    07 SW DCLB
    Thanks man. the more research im doing thats what im finding. just trying to get my tuck level for now so i can fit a bigger tire for the time being.
  10. Oct 18, 2013 at 10:32 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Don't buy a spacer lift. I have one and they suck. I am saving up for leafs, springs and shocks for a 3" lift
  11. Oct 18, 2013 at 10:39 AM
    Mr Salty
    Hermmy
    Lots of chrome
    Just do Bilstein 5100s in the front and set them to 1.75 setting (second notch) and leave the back alone. This will level you out, cost is very affordable, and you should be able to tuck slightly bigger tires under the wheel wells.
    But yeah there are tons of options out there, so do your research.
  12. Oct 18, 2013 at 12:22 PM
    kperickson
    Secret Town
    07 SW DCLB
    thanks for all the input. one last question will i need a diff drop kit or no. ive read all negative input about it but just making sure my cv's will be all good still
  13. Oct 18, 2013 at 12:23 PM
    User Name01
    Bolbi Stroganovsky
    You "dont need one" but I dropped mine anyways. Without it, the cv were too much at an angle with mine
  14. Oct 18, 2013 at 1:17 PM
    kperickson
    Secret Town
    07 SW DCLB
    ok thanks for the heads up
