Trail Toys NSA Switch Panel
Discussion in 'Trail Toys' started by SMKYTXN, Mar 18, 2015.
  1. Apr 27, 2017 at 9:34 PM
    #181
    MTSN
    MTSN Well-Known Member
    Denver
    17 Tacoma TRD Off Road
    I forgot to post up when I installed this. So far so good!
  2. May 22, 2017 at 10:01 AM
    #182
    HerT4R
    HerT4R Nomadic
    Her
    Bless the rains
    2 legs or 2 wheels
    '10 4RUNNER TE (SOLD)
    recently finished up my ARB dual compressor installation and was ready to wire it up to my NSA box. For anyone wondering how to do this, it is easy.
    Step 1:
    Cut off the supply loom spade connectors (or end connector if you've pressed the spades into the end connector). I cut it about 1" from the end connector just in case I want to ever reattach the supply loom to the switch loom.
    Step 2*:
    *If you do not have a need for the front or rear air locker wires (yellow & dk green, per schematic) then tape the yellow and dk green wires to the harness and out of your way and move on to step 3, this is what the figure shows since I do not have front or rear ARB air lockers at this time.
    *If you do have a need for the front or rear air locker wires to control your totally badass ARB air lockers then attach the yellow and dk green wires to separate output wires on the NSA trail toys box to control each locker individually. I recommend making the compressor #1 and then these #2 and #3 like @SMKYTXN did, but its your box do with it what you want but you need the compressor on BEFORE you go clicking your air lockers on and this method of wiring removes the idiot-proof switch loom....... don't say you weren't warned.
    Step 3:
    Attach the purple wire to an NSA trail toys box output wire (I picked #1, since it was my first accessory hooked to the box and it seemed important enough to be #1). And then attach the black wire to an appropriate ground.
    Step 4:
    press your selected output button on the remote, VOILA! air on demand!!!
    (if this didnt work verify your box is set up correctly and that the function that you picked is a "toggle" and not a momentary).
    knottyrope and SMKYTXN[OP] like this.
  3. Jun 2, 2017 at 7:37 PM
    #183
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I appreciate the update bud! :thumbsup:
    Blackout14 likes this.
  4. Jun 2, 2017 at 7:48 PM
    #184
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Dang i need one of these. Lights on lights on lights for days
    SMKYTXN[OP] likes this.
  5. Jun 2, 2017 at 7:54 PM
    #185
    SMKYTXN
    Nathan
    Houston
    DCFB
    I need to build a 4 relay version.
  6. Jun 2, 2017 at 7:54 PM
    #186
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'm restocking at the moment. Give me another week and I'll be ready for your order. :D
  7. Jun 5, 2017 at 8:46 AM
    #187
    HerT4R
    HerT4R Nomadic
    Her
    Bless the rains
    2 legs or 2 wheels
    someone has one for sale on the fj cruiser parts exchange on fb. pm me if you need the deets. its a great deal, looks brand new, with the indicator light panel.
    Silverspool[QUOTED] likes this.
  8. Sep 4, 2017 at 4:17 PM
    #188
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Control Issue....Frustrating
    Have had the NSA on my truck for 2 years, worked great. Haven't really used it all summer due to longer days, so I was checking things out this weekend and came up with an issue, the controller isn't staying "engaged". Bullet points below to explain....
    - Controller didn't work so I checked the box interior, clean and dry, no visible issues, changed battery in controller.
    - Went to re-program controller, interior panel light would not come on when pressing button.
    - Dis-connected power, checked the bottom of board all looks good.
    - Re-connected power, pushed button, light came on, re-programmed controller, lights worked as before, cool.
    - Started truck, everything still works fine, re-installed cover, everything still works fine, cool.
    - Moved truck to other side of driveway, checked lights, everything still works, cool. Engine off, drink beer, cool.
    - Check it 30 minutes later and Fuq, not cool, no lights.
    - Re-peat process from line 3 and same results. Works and then not works, not cool. Frustrated.
    - Did this 3 times, same results - works great, then it doesn't.
    - No other electronic changes in truck. Controller has always been kept next to my garage door opener in right cubby.
    - Closed garage door to check alignment, lights on-off no issues. Control system just seems to peter-out after awhile.
    - The panel has always been hooked direct to battery without issue, but I now notice the Blue Sea Circuit Breaker below and in others posts.
    IS it the controller, IS it the mother board switch, IS it the lack of breaker, IS it me................Help, input is appreciated.
  9. Sep 4, 2017 at 4:25 PM
    #189
    SMKYTXN
    Nathan
    Houston
    DCFB
    Sending you a PM Pete. We'll get this sorted.
  10. Oct 21, 2017 at 6:03 AM
    #190
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    ordered.......
  11. Oct 27, 2017 at 5:52 AM
    #191
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    And received last night.......super fast!
    Thanx!!!!!!
    Have to get it installed after get back from the camping trip this weekend....
  12. Nov 7, 2017 at 5:17 AM
    #192
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Subbed...I hope I remember this when I start adding lights and other fancy electronics haha
  13. Nov 13, 2017 at 7:21 AM
    #193
    HerT4R
    HerT4R Nomadic
    Her
    Bless the rains
    2 legs or 2 wheels
    its an easy peasy install just gotta mount and run power to the battery through a circuit breaker. if you need any assistance holler back on here. I for one love the NSA box and will proceed to tell all the sPOD fanboys i know about it. i love it when they get jelly...
  14. Dec 16, 2017 at 8:39 PM
    #194
    MTSN
    Denver
    I sold the Land Cruiser I had installed mine in, and now I'm into a new truck I'm thinking about adding another panel on. Curious if there have been any updates or changes to the panel in the last ~12 months or so? Has the remote design changed to something a little more sleek? Not a big deal, but it would be cool if there was an option for a smaller/more discrete remote.
  15. Dec 16, 2017 at 8:42 PM
    #195
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's nice to hear that you're considering a second one for the new rig. To answer your question, no there haven't been any changes in the last year.
  16. Dec 16, 2017 at 8:50 PM
    #196
    MTSN
    Denver
    I really liked the simplicity of it and being able to turn on/off from a distance. This one may go in the bed of a truck with an aluminum topper on top. Do you foresee any issues with the remote signal going through the aluminum topper and into a wooden storage box where the aux/second battery is?
  17. Dec 16, 2017 at 8:54 PM
    #197
    SMKYTXN
    Nathan
    Houston
    DCFB
    I don't see that being any different that the unit being placed under the hood. You should be fine.
  18. Jul 3, 2018 at 7:36 AM
    #198
    SMKYTXN
    Nathan
    Houston
    DCFB
    If you're in the market, now is the time to buy! Use code JULY4TH for 15% off all orders at trailtoys.net.
    Have a great week everyone!
    Nathan
    Rat_Bastard, GHOST SHIP and 113tac like this.
  19. Nov 20, 2018 at 9:01 AM
    #199
    Rat_Bastard
    Rat_Bastard Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    Do you have any in stock?
  20. Nov 20, 2018 at 12:37 PM
    #200
    SMKYTXN
    Nathan
    Houston
    DCFB
