Trail Toys NSA Switch Panel
Discussion in 'Trail Toys' started by SMKYTXN, Mar 18, 2015.
  1. Mar 23, 2015 at 10:26 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    If you have a blue sea fuse panel set up already then you're life just got easier. You can remove the blue sea panel and replace it with the switch panel. Hook the +12v hot wires from the switch panel to the wires you've already run for your accessories and you're done.
  2. Mar 23, 2015 at 4:57 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Is this waterproof?
  3. Mar 23, 2015 at 5:41 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    See post #2
  4. Mar 23, 2015 at 6:04 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    Oops
  5. Mar 23, 2015 at 8:50 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    you should buy this too! wish i had a need for a device this cool.
  6. Mar 23, 2015 at 8:55 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    It sounds like you need more accessories. :D
  7. Mar 25, 2015 at 8:50 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Do you have any warranty on your design?
    Also,
    Does it use standard relays I can buy at an auto store, or is a relay that I would only have to buy through this company?
    Can I configure for 10 or 12 accesories instead of 8?
    I am considering this for my 4runner build:
    1. ARB rear locker
    2. Compressor
    3. Auxilary lights 1
    4. Auxilary lights 2
    5. Power outlet
    6. Rock lights
    7. Winch out
    8. Winch in
    9. Future?
    10. Future?
  8. Mar 25, 2015 at 8:57 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'm still ironing out what I can offer as far as a warranty. I will personally test each panel before it ships out, and set it to your desired setting.
    As far as longevity, these relays are pretty much bullet proof. They are not standard automotive relays though. They are RF capable relays, which can be bought on Amazon for about $5.
    As far as your setup, you'll have to make a few changes. The panel has eight relays only, so 9 and 10 won't work. You'll also need a channel to power your winch. So 6, 7, and 8 will be; winch power, winch in, and winch out.
    What do you mean by power outlet? I would think that if it's just an outlet, either 12V or 110 you don't need a switch for it. Just wire it up hot.
  9. Mar 25, 2015 at 9:06 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Thanks for the input.
    In regards of 9 and 10 not working, that was my question.
    Could you make panels with more relays, say a 9 and 10 for more than 8 accessories?
  10. Mar 25, 2015 at 9:10 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    In the future I can, but I'm starting with this 8 relay panel. Once the 8 panel is off the ground and selling I will poll people on what changes they would like to see.
    And you can always buy two panels. :D 16 accessories!
  11. Mar 25, 2015 at 9:13 AM
    ramonortiz55
    Ramon
    Texas
    stock
    So what if we need to reprogram it?
    Do we need to send it back to you?
  12. Mar 25, 2015 at 9:18 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Nope, you can do that yourself. I'll be including a full instruction sheet.
    There's a button on the board. Push the button to put the board into "learning mode", then press the button on the remote that corresponds to the setting you want and you're done.
  13. Mar 25, 2015 at 9:20 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :spy:
    that's enough for now.
    thanks..
  14. Mar 25, 2015 at 9:30 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I appreciate the questions. If you have more later please let me know.
  15. Apr 7, 2015 at 3:37 PM
    #35
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll have a demo video ready shortly, so everyone can get a better idea of how these relay panels work.
    Keep in mind, that you don't have to wire the box, it's basically plug and play. Find a spot for it under the hood, hook up power and ground, and run the positive leads to your accessories. That's all you have to do. Easy peasy! :D
    If you have any questions please let me know.
  16. Apr 7, 2015 at 3:42 PM
    #36
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    This is a really cool product!
  17. Apr 7, 2015 at 3:52 PM
    #37
    TexasPreRunner
    Anthony
    2011 PreRunner
    That it is! I've seen it in person and it works flawlessly
  18. Apr 7, 2015 at 9:28 PM
    #38
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Deposit sent. :D I'll probably want a backup remote -just in case.
  19. Apr 7, 2015 at 9:35 PM
    #39
    SMKYTXN
    Nathan
    Houston
    DCFB
    Got you on the list Brian. :thumbsup:
    I do not have a supply of backup remotes on order yet, but will get on that. Just keep the remote in the center console and you'll be just fine. The only time mine comes out of the truck is when I'm retrieving my winch line after a pull.
  20. Apr 7, 2015 at 9:40 PM
    #40
    SMKYTXN
    Nathan
    Houston
    DCFB
    Well here's some good news. My supplier just informed me that the first ten units will be finished tomorrow and should be shipped out by the end of the week. :woot:
