Trail Toys NSA Switch Panel
Discussion in 'Trail Toys' started by SMKYTXN, Mar 18, 2015.
  1. May 25, 2016 at 12:54 PM
    #161
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Ordered Sunday and already have the panel and everything wired up. This is an awesome product! Gonna be so much fun while night wheeling and camping. +1 Nathan!
    SMKYTXN[OP] and Blackout14 like this.
  2. May 25, 2016 at 1:03 PM
    #162
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Interesting piece of equipment.
  3. May 25, 2016 at 1:16 PM
    #163
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Try doing that with a bunch of rocker switches, relays, fuses, and random wire running around. Glad it worked out for you Kase. What are you controlling with your NSA?
    :thumbsup:
    Let me know if you have any questions.
    Blackout14 likes this.
  4. Aug 1, 2016 at 6:24 PM
    #164
    SMKYTXN
    Nathan
    Houston
    DCFB
    20k for a boat that I have to push along myself?
  5. Aug 1, 2016 at 6:30 PM
    #165
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'm not so sure my boxes would withstand submersion. I'd have to build a new box if we're going to go to that extreme.
    That's just nuts! I was going to say that it's just "fishing", but I'm guessing these guys are making a living off of it, so more power to them.
  6. Aug 1, 2016 at 6:35 PM
    #166
    SMKYTXN
    Nathan
    Houston
    DCFB
    Good point. The box will survive a good amount of water. It would be nice to not have to cut in holes to mount switch panels.
  7. Jan 24, 2017 at 12:46 PM
    #167
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    @SMKYTXN - What is the link to your website?
  8. Jan 24, 2017 at 2:59 PM
    #168
    SMKYTXN
    Nathan
    Houston
    DCFB
    It's in my signature. Did you try searching Trail Toys and not find it? That would be good information for me to know if so.
    Nathan
  9. Jan 24, 2017 at 3:11 PM
    #169
    bajatacoguy
    Johnny
    RI to NH
    Blk Taco
    I clicked an earlier link and the path was dead.
    I did find it
    Ty
    SMKYTXN[QUOTED][OP] likes this.
  10. Jan 24, 2017 at 4:02 PM
    #170
    SMKYTXN
    Nathan
    Houston
    DCFB
    Good deal. Let me know if you have any questions.
  11. Jan 25, 2017 at 10:00 AM
    #171
    NoOneBetter
    NoOneBetter Well-Known Member
    Bryant
    San Jose, CA
    2015 4Runner Trail Premium
    If for some reason you wanted an additional/backup physical switch for one of your accessories, could you just tap into the lead wire for your accessory coming out of the NSA switch panel with a physical switch/power?
  12. Jan 25, 2017 at 10:41 AM
    #172
    SMKYTXN
    Nathan
    Houston
    DCFB
    It won't work like that. You'd have to have a completely separate switch, power, and relay. You'd also want to put some sort of diode in line with both switches so you don't back feed either one.
  13. Jan 25, 2017 at 10:51 AM
    #173
    NoOneBetter
    Bryant
    San Jose, CA
    ok, cool. Thanks for the info.
  14. Mar 21, 2017 at 3:42 PM
    #174
    MTSN
    MTSN Well-Known Member
    Denver
    17 Tacoma TRD Off Road
    I'm really liking this option and thinking about ordering it. I really don't like running wires through my firewall, but I'm also an electrical newb. I have a couple of questions though for those who've installed it.
    - Besides the actual kit itself, what else do you have to buy to install? It looks like: a circuit breaker, 4 gauge wiring, 4 gauge crimp terminals, extra wiring to run to each accessory, extra butt connectors, and then optionally a bus bar for grounds, wiring loom, and maybe others? Is that the full list? Since I'm not very experienced wiring, it's a little intimidating to have to pull so much stuff together that's not in the kit.
    - Does the kit come with easy to follow instructions?
    - Is there any kind of warranty in the case of a failure or if one of the relays or something spontaneously combusts? One of the nice things about the big name like Spod is that I'm sure there's a warranty/insurance if something bad happens.
    shawnMc likes this.
  15. Mar 21, 2017 at 4:22 PM
    #175
    SMKYTXN
    Nathan
    Houston
    DCFB
    Here's your shopping list.
    • 150Amp circuit breaker or fuse
    • 4gauge crimp terminals (There's plenty of wire length to reach the battery if you place the NSA near your fuse panel)
    • 14 gauge hot wire for accessories that are outside the 4' length of wire the kit comes with.
    • Ground all of your accessories to the chassis as close to the accessory as possible, no need for a buss bar.
    • Wire connectors
    Instructions are fairly simple. Run power to the box via the 4gauge wire. Ground the box with the black wire in the wiring harness, then run the red power wires to all of your accessories. It's that simple.
    I'm too small of a company to offer a big warranty. I cover issues as they come up, which isn't very often at all. Be sure you look up the big name warranties before you assume you're covered.
    Let me know if you have any other questions.
    MTSN[QUOTED] likes this.
  16. Mar 21, 2017 at 4:45 PM
    #176
    MTSN
    Denver
    Ok awesome thanks. Would you suggest just cutting in half the existing 4 gauge wire coming out of the box and using half to connect to the fuse box and the other half to connect to the battery? Cable looks think hopefully my cutter would work haha.
  17. Mar 21, 2017 at 4:47 PM
    #177
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    How did you hook up the power to the winch?
    I still haven't set mine up yet, haha
  18. Mar 21, 2017 at 4:48 PM
    #178
    SMKYTXN
    Nathan
    Houston
    DCFB
    That's exactly what I did when I installed mine. My wire cutters weren't up to the task so I used bolt cutters. :D
    Run a hot lead to the solenoid power in and a second to the solenoid power out.
    HerT4R likes this.
  19. Apr 12, 2017 at 10:45 AM
    #179
    MTSN
    Denver
    I'm finally getting around to wiring everything up this weekend, and I realized my wire isn't 14 gauge it's 16 gauge :( I'm only wiring up LED scene lights and a 40" single row light bar, so do you think this wire I bought a while back will be sufficient?
    https://www.amazon.com/gp/product/B003HGHO7Q/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B003HGHO6W/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
    And this is the light bar:
    https://www.amazon.com/gp/product/B01D0HARPC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
  20. Apr 12, 2017 at 11:08 AM
    #180
    SMKYTXN
    Nathan
    Houston
    DCFB
    You'll have to look at how many amps the light will pull, then at how many amps the wire can handle.
    MTSN[QUOTED] and HerT4R like this.
