Trailer Brake Controller Wiring Question
Discussion in 'Towing' started by Scott B., Feb 29, 2016.
  1. Feb 29, 2016 at 8:37 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I installed a Tekonsha P2 brake controller using a wiring harness from eTrailer that attached to the Toyota factory harness.
    Installation was a breeze, and it works great.
    As wired, the brake controller always has power.
    My question is, should I wire a switch (a 20 A switch or switch/relay combination) so the controller is only powered up when I am using it, or is it preferable to leave it on all the time?
    I had it switch on my other truck, and it worked fine. It has been wired on this truck for about 8 months, and works fine as well.
  2. Feb 29, 2016 at 8:56 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It should be wired to have power only when the key is on. If you don't tow much just disconnect the controller. If you are afraid of loosing it or rather leave it in then put a power switch in. I don't see any reason it would hurt it.
  3. Feb 29, 2016 at 8:56 AM
    dumbassdave
    dumbassdave Active Member
    Dave
    BC, Canada
    07 SR5
    I think that the brake controller will shut off eventually, after 15 minutes or so. My sister's Tacoma had the factory harness and hers shuts off after a while. She has the Tekonsha P3 though, so it is possible that the P2 is different. In my Tacoma I didn't have the factory harness so I installed a relay so that my brake controller would turn on/off with the ignition.
  4. Mar 1, 2016 at 7:42 AM
    Indy
    Indy Master of all I survey.
    Mine turns itself off, direct connection to the battery.
  5. Mar 6, 2016 at 9:18 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    My P2 is also wired through the factory harness, and is always hot. The controller turns itself off after 15-20 minutes.
  6. Mar 7, 2016 at 12:19 PM
    Indy
    Yep, besides the LED's on the front there's going to be pretty much 0 amp draw unless you have a trailer connected. No reason to have it switched.
  7. Mar 7, 2016 at 5:23 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    and even then there would be no draw unless the brake pedal was activated.
    I've got the "lil brother" of the Prodigy controllers the Primus IQ in both my Runner and my Tacoma, the one in my Runner has been installed for 5 years, never an issue with battery run down, had more issue with my wife leaving the lights on and killing the battery....
  8. Mar 21, 2016 at 4:51 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Why is their still a white wire with a grounding ring on the prodigy set up?
    Shouldnt the factory plug already be grounded? Thanks
  9. Mar 21, 2016 at 5:43 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    It's ground for the controller itself not the brakes or trailer
    Can't have too good of a ground, redundancy is good here
  10. Mar 21, 2016 at 6:12 AM
    blazze2005
    South Jersey
    Thanks im ordering the prodigy
