Trailer brake install ??????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wannabee, Oct 28, 2015.
  1. Oct 28, 2015 at 5:18 PM
    Wannabee
    Wannabee [OP] Well-Known Member
    Troy
    2016 SR Access cab 2.7 Silver Sky
    I have the utility package , basic truck . I know others have the towing package with a pig tail already installed , I am assuming that is not the case on my part.
    Is it possible to install a unit with causing a problem ?
  2. Oct 28, 2015 at 5:21 PM
    scocar
    scocar hypotenoper
    Might want to post this in the towing forum.
    https://www.tacomaworld.com/forums/towing.34/
    Also, if you are towing something heavy enough to require trailer brakes, you should be concerned about a few other things, like the rest of the harness, and possibly tranny or oil cooler. Do you have a manual or AT?
  3. Oct 28, 2015 at 5:35 PM
    Atticus9288
    Atticus9288 Active Member
    PA
    2016 Bbp Tacoma sport TRD
    Chances are if your towing something that has its own breaking system, it may be exceeding the towing capacity of the truck.
  4. Oct 28, 2015 at 5:48 PM
    Wannabee
    Troy
    It's a small travel trailer that is within towing specs
  5. Oct 28, 2015 at 8:09 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Blatantly false. Lots of states require trailers above 2000lbs to have brakes
  6. Oct 28, 2015 at 8:11 PM
    scocar
    scocar hypotenoper
    What's the weight, and also check your state's specific laws. In CA, it's 1500 lbs+ requires trailer brakes.
