Trailer brake issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hcore400, Mar 25, 2024.
  1. Mar 25, 2024 at 1:04 PM
    Hcore400
    Hcore400 [OP] New Member
    cory
    2007 blue Tacoma TRD Sport
    Airbags, Bilstein 5100, Fuel wheels, Overland rack
    I have an 07 Tacoma double cab TRD Sport with the factory tow package installed, 7 pin connector.
    The issue I'm having is knowing what the voltage should be on the blue brake wire when in park with brake pedal pressed. I'm getting millivolts and don't know if it gradually feeds voltage while braking in tow or I've got issues. This is my first trailer with brakes. Everything else on that connector gives me 12+ volts where it should be.
    Side note, I've went through all the relays and fuses, plus I have put in a new factory controller in the driver side kick pannel. I've also back traced all of the wires to look for cuts.
  2. Mar 25, 2024 at 4:43 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It depends how your controller works, some won't output anything unless they sense a load on the circuit.
    I always test them with a test light.
    TnShooter likes this.
