Trailer brake lights don't work but turn signals do.
Discussion in 'Towing' started by cmf21, Jul 27, 2011.
  1. Jul 27, 2011 at 12:39 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Borrowing a trailer again with a 7 way plug. Trailer has leds, no bulbs. I have a 4 way plug. In the past, I've been opening up the trailer plug and connecting a spare 4 way wire plug so i can hook it up to the plug on my truck.
    Everything works like usual except the brake lights don't work. I can't figure out the problem. I've done this at least 20 times with the brake lights working.
    I have the ground wire white/white connected, yellow wire for the left turn signal, green wire for the right turn signal, and the brown for the tail lights.
    Brake lights don't work. What could the problem be?
  2. Aug 10, 2011 at 5:41 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Do you have a light converter installed?
  3. Aug 10, 2011 at 5:45 AM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Not sure how the Tacoma fuse box is configured for the tow package, but you may have a blown fuse on the truck. Since the trailer appears to be juice to the turn signals, and since its an LED setup, most likely it is an issue with the truck.
    If you have a test light you can determine if the truck is the issue quickly. Hook up the ground on the test light and have someone hit the brakes in the truck, the yellow and green wires should have solid power to them when the brakes of the truck are on
