trailer brake problem
Discussion in 'Technical Chat' started by taco1985, Apr 4, 2011.
  1. Apr 4, 2011 at 2:06 PM
    taco1985
    taco1985 [OP] Member
    North Arkansas
    2008 Tacoma Double Cab
    Viper Alarm
    Hello Everyone! I am new to the forum and have a question about my toyota. I have a 2008 tacoma double cab. I read in the manual that I have a factory hook up by the drive kick panel under the dash for trailer brakes. I bought a trailer brake kit from the parts store and a wiring harness from Toyota to hook up to the connector under the dash. I hooked everything up but I do not have any power coming out of the factory installed hook up. I tried putting fuses in the fuse box listed towing, trailer lights and a relay for trailer lights. Nothing has produced any power to the hook up. Surely someone else has ran across this. I called the dealer but they were not much help. Can somebody help me out??
  2. Apr 4, 2011 at 4:02 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Welcome to TW.
    I'm not familiar with the hook up though sorry, just didnt want you thinking you're being ignored.There is a trailer section down a few areas, if i recall there was a hookup section there that might shed some light on it.
  3. Apr 4, 2011 at 5:40 PM
    taco1985
    North Arkansas
    Viper Alarm
    Thanks. I appreciate the welcome. I will check out the other thread.
  4. Apr 4, 2011 at 6:34 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    I answered your question in the other thread.
    The answer was: Put a 30 Amp fuse in the TOWING BRK slot in the fusebox under the hood. Ignore all of the other towing fuses and relays.
