trailer brake question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spyshot, May 31, 2009.
  1. May 31, 2009 at 5:28 AM
    spyshot
    spyshot [OP] Well-Known Member
    Dayton Ohio
    09 TDR OFFRoad
    just purchased a 09 trd with towing package. it has a factory installed 7 pin trailer hookup. here is my question...I'm used to having a separate, aftermarket trailer brake controller. if i hookup a trailer with electronic trailer brakes, do i have to buy and install a trailer brake controller? how does this all work?
    thanks
  2. May 31, 2009 at 6:33 AM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    yes you have to buy a brake controller. the truck is wired for it but you have to buy one. there should be a pig tail wire in your glove box to use. have to plug it in under your dash by the emergency brake then wire it to your controller
  3. May 31, 2009 at 7:31 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Aside from what 09 tacoma trd has already said...
    Having a brake controller allows you to fine tune the braking for the load you are towing. The heavier the load, the more braking pressure you'd need versus a smaller load that wouldn't need as much.
    If you had too much braking power for a smaller load, that would cause the tires to skid - etc.
    Also - some of the brake controllers have a 'lever' which you can activate the trailer brakes separately from the vehicle. This is GREAT especially for going downhills if the trailer starts to sway - you activate the trailer brakes to help straighten things out.
  4. May 31, 2009 at 8:37 AM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    thanks for the info! so that's what that adaptor in the glove box is for. That was a future question.
    thanks again
  5. May 31, 2009 at 10:09 AM
    Redfox458
    Redfox458 Well-Known Member
    07 Tacoma TRD Sport Access Cab
    So then where exactly is the plug for the trailer for the trailer brakes? I have an 07 access cab, and can't seem to find the trailer brake plug near my hitch....:confused:
  6. May 31, 2009 at 10:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If your looking for the part that connects to the brake controler, its behind the drive side kick pannel.
  7. May 31, 2009 at 11:05 AM
    Redfox458
    actually looking for a plug that comes from the trailer to the back of the truck near the actual hitch (stinger). I've got a friend's single axle trailer he wants moved, but needs the electric brake. I hooked up the trailer to my truck and noticed I've got nowhere to plug in his wiring plug. I have the regular plug (trailer lights) plugged into my truck, and all the trailer lights work. The trailer is in no means a regular trailer, so maybe it has aftermarket electric brakes?? I know a lot of electric brakes and their brake lights are all wired into the same plug....
  8. May 31, 2009 at 12:30 PM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    if you have the 7 pin hookup on your truck, then yes, the brakes are integrated into that plug. see link.
    http://www.etrailer.com/faq_wiring.aspx
    4 pin connector is for lights only
  9. May 31, 2009 at 1:56 PM
    Redfox458
    Okay, yeah I have the stock electrical hookup on my 07 TRD Sport. Maybe I'll tell my friend with the trailer to re-wire the brakes! Thanks for the help spyshot!
  10. Sep 27, 2011 at 9:21 AM
    greenacresusa
    greenacresusa New Member
    07 SR5
    Sooo if I have the 7 pin hookup on my truck (2007 TRD Sport Double Cab) I DON'T need the brake controller? I haven't had to tow anything yet but will soon so I need to know. Thanks
  11. Sep 27, 2011 at 9:50 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes you still need the controller if you have the factory 7 pin connection it is wired but you still need the controller and the Toyota pig tail to complete the connection there are many controllers on the market so that is why Toyota supplied the pig tail so you could chose the controller you wanted. You can't just plug it it in and expect the brakes to work there has to be some type of control or the trailer brakes would lock up as soon as you step on the brake no matter how fast or slow you were going.
  12. Sep 27, 2011 at 10:21 AM
    greenacresusa
    07 SR5
    Thanks!! I've only had this truck for a few months. I had a F150 before that I added the brake controller and all the towing components but never had a factory installed towing package before. I'll get going on getting the parts and have them installed asap. Thanks again.
