Trailer brakes won't grab
Discussion in 'Towing' started by locster, Aug 16, 2018.
  1. Aug 16, 2018 at 3:31 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    My trailer is roughly 2000#, but I can't get its electric brakes to work. I set the P3 brake controller up to 12V, and adjusted the brake magnets at the drums as close as possible, but it's stil not enough to stop the trailer. I can hear the brakes being magnetized when I hit the brake or slide the brake lever on the controller.
    What else should I check?
  2. Aug 17, 2018 at 4:34 AM
    Indy
    Indy Master of all I survey.
    Check voltage and ground at the brakes, just because you have 12v at the plug doesn't mean you have 12 at the brakes.
    Trailer brakes wear just like regular brakes.
    Define "stop the trailer". It shouldn't take much to stop 2k. Can you make the wheels lock up? Are you trying to stop the truck and trailer with just the trailer brakes?
  3. Aug 17, 2018 at 4:36 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you checking while in motion? The P3 has an inertia bias built in.
  4. Aug 17, 2018 at 4:38 AM
    Indy
    Manual lever should bypass the controller completely.
  5. Aug 17, 2018 at 6:05 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    IRCC the P3 instruction manual states that you should increase the power setting until you're able to fully lock the brakes while towing at 25 MPH using the override lever. All trailers and brakes are different but in my experience 12 sounds like a good setting for a 2000 lb trailer. But anyway, can you lock the brakes using the over ride function? I don't know what you mean by "stop the trailer". You wont be able to stop the truck and trailer combo very well using only the trailer brakes because your truck is much heavier than the trailer.
  6. Aug 17, 2018 at 11:41 AM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Thanks all for the replies. By "stopping the trailer," I am referring to trailer wheels locking up or create enough drag to slow down the truck and trailer at a 5mph roll. I tried the 15mph brake check with the manual brake override, but that was too fast to notice anything, so I tested at much slower speed.
  7. Aug 17, 2018 at 11:46 AM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    That's exactly the test I did. The max power setting on the P3 is 14, so I think 12 is way too much for a 2000# trailer. I was expecting wheels locking up at around 4 at 15mph.
  8. Aug 17, 2018 at 11:51 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    If the drums are fine, maybe check the voltage that's getting to the brakes? Since it's newer, it seems unlikely that your truck's system is faulty. Maybe the trailer isn't wired correctly?
    locster[OP] likes this.
  9. Aug 27, 2018 at 5:19 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    While braking with the P3 it will display the current voltage applied. This is determined by the settings and the inertia. When I apply the brakes softly at low speeds it barely applies the trailer brakes at all.
    If while manually applying the brakes you still get nothing I would pull your trailer with another vehicle and test the brakes with their controller to verify if the problem is with the trailer. If it is good then you know you have an issue with your truck / controller and it’s system.
  10. Nov 14, 2018 at 3:04 AM
    SouthFloridaFJ
    SouthFloridaFJ New Member
    Boynton Beach FL
    2018 Cement DC Tacoma 4x4 Sport
    OEM Roof Rack,4Runner wheels with BFG ATs,Pro X15 Tonneau Cover,Knock Off Pro Grill
    Remove all scotch locks from the brake wiring if present and replace them with butt connectors.
  11. Nov 17, 2018 at 9:11 AM
    Toyanvil
    Toyanvil Well-Known Member
    Both my trailers did the same thing with my 08 Tacoma. I found that the ground wire at the trucks plug-in starts as a 10 awg and goes to a much smaller wire about 10" from the plug-in and grounds to the top of frame at the drives rear wheel. I sliced a 10 awg wire to the 10 awg truck wire and grounded it to the hitch, my trailer brakes work great now.
