trailer GPS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Apr 21, 2014.
  1. Apr 21, 2014 at 7:00 PM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    So does anyone have any suggestions for a GPS that will work with a landscape trailer? I was looking for something small that would activate when the 4 way flat plug was plugged into the truck. Not sure if that would work or if they make anything like that. I don't want to have worry about batteries.
  2. Apr 21, 2014 at 7:13 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    There are several choices but most are going to be geared toward an 18 wheeler trailer. I dont have any specifics but know they are out there.
  3. Apr 21, 2014 at 7:18 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If your trailer has electric brakes, then you are most likely using a seven pin trailer plug. One of the contact in that plug is hot whenever the trailer is plugged into the tow vehicle.
    Why are you wanting this feature? Do you just want to keep track of the miles you put on the trailer.
    If you need something like that, I use an app called "mytracks" it will record your route and you can email the route to anyone.
  4. Apr 22, 2014 at 4:43 PM
    Squirrellydw
    I only have a 4 way flat so no trailer brakes. I wanted it incase it would get stolen. My thought was when the wire harness was plugged in it could power the GPS. That way I would have an idea of where it was. If it was small enough I could hide it and hopefully the thief wouldn't know. Not to worried about it getting stolen but better safe than sorry.
  5. Apr 22, 2014 at 5:42 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There is no constant or ignition power on a 4 pin flat plug, so it would have to run off the tail light circuit, meaning you might only be able to track it when its being used at night. Unless you were to add a diode and a 12v battery that would charge off the tail light power when the tail lights are on, then power your GPS tracker off that battery. Honestly, it sounds to me like much more of a hassle than its worth for a landscape trailer.
  6. Apr 22, 2014 at 7:14 PM
    Squirrellydw
    I didn't think they had anything but thought I would ask. As for only tracking it at night, I would think it would work any time but I have no idea
    thanks
  7. Apr 22, 2014 at 9:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    10 dollar chain and lock???
  8. Apr 22, 2014 at 9:46 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  9. Apr 22, 2014 at 9:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  10. Apr 23, 2014 at 5:30 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ok let me get this straight. You have a GPS in the trailer it is going you let you know just where the trailer has been but with out some type of tracking how are you going to know where it's hiding?
  11. Apr 23, 2014 at 8:15 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Just insure it and use a coupler lock. And if you are going to leave it for a while and are worried about it, put it on a jackstand and take a wheel off.
