Trailer Harness Relocate Brackets
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by YumaTRD, Dec 4, 2011.
  1. Dec 4, 2011 at 11:44 AM
    YumaTRD
    YumaTRD [OP] The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I've made 24 set of "L" brackets designed to move the 7 pin trailer connector harness to a safer location.
    I used Galvin's (Ilovetacos) method and it has worked great for me.
    The thread can be found here http://www.tacomaworld.com/forum/2nd-gen-tacomas/114216-diy-relocate-trailer-harness.html#post3316038
    a batch im prepping for paint
    This method is completely bolt on and takes minutes to install.
    The Aluminum L brackets will come spray painted black and with the extra bolts needed for the install.
    Temporarily sold out
  2. Dec 4, 2011 at 1:08 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    nice work. i have a back up light plugged into mine that i really like, and i dont offroad heavily so i dont need one.
    if someone were to go to home depot and but some brackets, bolts and paint they would pay very close to $20 so i say great deal
  3. Dec 4, 2011 at 3:51 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Come to Az- lets wheel that RIG!
    I sent ya a PM, I'm tired of worrying about that thing getting broken off.
    Thanks,
    Azbackcountry
  4. Dec 4, 2011 at 5:13 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Thanks Sean, Just trying to have fun fabing stuff and passing on the savings!
    Pm Replied :)
  5. Dec 4, 2011 at 5:24 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    How low would the harness hang down once plugged in?
  6. Dec 4, 2011 at 5:49 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    This is the only pic I have to show the plug. The trailer hitch and ball will hang lower that the plug. The hitch will hit before anything else when towing.
  7. Dec 4, 2011 at 6:01 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    I agree. It looks great. Too bad there is no locking mechanism to allow it to fold over. I also have a light in there but do like to off road. Good luck. It's at a reasonable price as well.
  8. Dec 6, 2011 at 8:28 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Thanks Albert!
    I've already sold one set and I have a couple ready to ship!
  9. Dec 6, 2011 at 10:52 AM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Wish I had this before I completely destroyed my harness...
  10. Dec 6, 2011 at 12:15 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Thanks for the compliment, It's hard to get yourself to spend on preventative mods but it pays off in the long run.
  11. Dec 6, 2011 at 2:07 PM
    AZBACKCOUNTRY
    Doug
    Installing it Friday! Nice seeing you again David!
    Doug
  12. Dec 7, 2011 at 2:56 AM
    darcivic00si
    darcivic00si Love this forum!
    Darci
    Tucson, AZ
    '20 Super White TRD PRO Manual!!!
    Could you ship this to a military APO address? It is like a stateside address so pretty much the same cost, you just need to fill out a customs form.
    I can send some extra $ if needed...thanks!
  13. Dec 7, 2011 at 8:16 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    shouldn't be a problem. Pm'd
  14. Dec 7, 2011 at 10:03 PM
    darcivic00si
    Darci
    Tucson, AZ
    Sweet,I just sent the $ through paypal! I will let you know when I get them.
    Thanks again!
    Darci
  15. Dec 7, 2011 at 10:05 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Very nice! They look good!
  16. Dec 9, 2011 at 8:05 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Thanks again for letting me use your idea!
  17. Dec 9, 2011 at 8:16 AM
    pudge151
    Sean
    Connecticut
    bump for you sir
  18. Dec 9, 2011 at 9:39 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Back to the top....
  19. Dec 10, 2011 at 2:54 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Sent yah a pm, I'll take a set!
  20. Dec 10, 2011 at 7:49 PM
    AZBACKCOUNTRY
    Doug
    Totally productive day. Swapped out the chrome (won't take you home) bumper for a silver Mica OEM bumper. Then mounted the new trailer hitch pin with your mount!
    It's OUTSTANDING. I had already bent the metal bracket that holds the 7 pin. So I straightened that up, and bolted it on. It's in MUCH better location and much less susceptable to being smashed by an Arizona boulder - LOL!
    Thanks again ! Well worth the investment and piece of mind!
    Azbackcountry
