Trailer harness running lights only working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pvs01, Oct 13, 2017.
  1. Oct 13, 2017 at 3:04 PM
    Pvs01
    Pvs01 [OP] Member
    hello all,
    New to the forum. Great info here. Anyway, towing my boat and noticed my brake and signals not working. Put a multimeter to the harness and only get 12v from the running lights and nothing from from the brake turn signal. Please help truck is 4 months old. Dealer needs all day they say. “Could be rodent”.
    Thanks in advance.
  2. Oct 13, 2017 at 3:05 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Can you crawl under your truck and see if any of the wires are chewed up?
  3. Oct 13, 2017 at 3:18 PM
    Pvs01
    Pvs01 [OP] Member
    No wire chewed up. Everthing looks good. I wonder if anyone has the wiring schematic.?
  4. Oct 13, 2017 at 4:38 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Possibly a fuse..??
  5. Oct 13, 2017 at 6:47 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    USE YOUR WARRANTY!!!!
    G.
  6. Oct 13, 2017 at 7:34 PM
    Pvs01
    Pvs01 [OP] Member
    All fuses are working. Dealership is giving me the “ it might not be under warranty if a pest chewed some wires”. I am bringing in Wednesday. They said they need all day with it.
  7. Oct 13, 2017 at 8:41 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I have a cheap tester that checks the plug (connector) at the rear of the truck. Plug in and run your normal checks for running lights, brake, signals, power (7pin). In my experience it is usually the tow harness on the trailer that has lost a ground or other connections. Rarely is it the truck harness unless a fuse has blown (or a dodge which blows the unserviceable towing only flasher every 2 years).
    Check online for the tester I am speaking of. It is a huge time saver.
    Edit:
    https://www.etrailer.com/Accessories-and-Parts/Tow-Ready/TR20117.html
    No this won’t void your warranty (you really think this is screwing with your truck?) but if you go to your dealer and the issue was your trailer I suspect they will charge you shop rate for their time. Best to eliminate the trailer first.
    over60 likes this.
  8. Oct 14, 2017 at 5:50 AM
    Garyji
    Gary
    The tester is a good idea. However, if it's an issue with the brand new truck, don't give Toyota a reason to say "you screwed with it, so it's your problem". If it is rodents, well, then that sucks and can be very expensive.
    Keep us posted.
    G.
  9. Oct 14, 2017 at 6:07 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Get a test light and check for power at each pin. If you have power at rear of truck -- it's most likely your trailer ground or wiring.
  10. Oct 14, 2017 at 6:34 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Check the ground connection on the trailer, with some trailers I've used a jumper wire with clamps from truck frame, to the trailer frame.
    over60 likes this.
  11. Oct 14, 2017 at 7:26 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    wiring schematic
  12. Oct 14, 2017 at 10:06 AM
    Garyji
    Gary
    Stop by a U-Haul place and see if they will let you hook up to one of their trailers.
    G.
  13. Oct 14, 2017 at 4:11 PM
    Pvs01
    Pvs01 [OP] Member
    /pickupman2007 thanks for the schematic. There is no power going to the back of my trailer harness on my truck except for running lights. Check them with a multimeter.
  14. Oct 16, 2017 at 12:58 PM
    Pvs01
    Pvs01 [OP] Member
    I noticed a wiring clip by the driver side fuse box that isn’t plug in to anything59AFAA11-1539-4A23-ABEE-8AA1781B765E.jpg4F67ADDD-8844-4D85-B726-BAF4BAEEEA20.jpg
  15. Apr 16, 2019 at 7:50 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    Did you check all your fuses?
    If you checked the plug on the back of your truck without a trailer plugged in and there's nothing there, I don't see what it could be other than blown fuses or damaged wires.
