Trailer Hitch Recovery Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mpivovar, May 13, 2016.
  1. May 13, 2016 at 11:05 AM
    mpivovar
    mpivovar [OP] Well-Known Member
    Alberta
    2011 Tacoma
    Is it safe to recover via a shackle in a Class 3 Curt Hitch. The hitch is rated for 5000lbs does that effect the size of vehicle you can recover or just the size of trailer you can tow. Would recovery strap break first? Does hitch have to be heavier?
  2. May 13, 2016 at 11:21 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  3. May 13, 2016 at 11:37 AM
    Pigpen
    Dan
    Northwest Montana
    I put a shackle in a hitch intended for a ball on my class 3 hitch all the time. It's plenty strong. You seem to already know not to use a ball for recovery, so +1 internets for you!
  4. May 13, 2016 at 5:13 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Friend tried to jerk someone out by ball and the ball stud broke. Nylon strap acted like a rubber band and slung ball through rear window hitting GF in back of the head.
  5. May 13, 2016 at 11:10 PM
    Pigpen
    Dan
    Northwest Montana
  6. May 14, 2016 at 12:13 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Did she survive?
  7. May 14, 2016 at 5:53 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Got any video?
  8. May 14, 2016 at 6:51 AM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    That's bad, mmmmmkay. Hope she was ok. And the gf too. As for the hitch shackle combo.....I yanked a Suburban out of the mud several years ago using one. I would do it again. Good luck and be safe.
  9. May 14, 2016 at 4:15 PM
    stump jumper
    Bill
    Texas
    Nope, dead on impact
