Trailer Hitch Thickness issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dwillhere1, Jun 24, 2019.
  1. Jun 24, 2019 at 8:20 AM
    dwillhere1
    dwillhere1 [OP] Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    Morning All
    Sorry if this has been discussed but I don’t see it. Trying to run a hitch pin that I currently own but with the double wall thickness it does not fit. On my 08 I was able to use a unibit to open it up more. I started doing this a while ago but don’t want the entire holes opened up that much. Purchased a hitch safe on Amazon not long ago and tried to install over the weekend. Same issue with the outer wall being in the way. Curious if someone has an easier fix with specific dremel tool or something to open up just the outer layer? Thanks everyone!
  2. Jun 24, 2019 at 8:31 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Because this is a Class IV hitch, it is thicker and needs a longer pin. Not advisable to machine the hitch in any way. Buy the longer pin.
    Tullie D, dwillhere1[OP] and Vbpiper like this.
  3. Jun 24, 2019 at 8:37 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Buy a longer pin.
    Tullie D and Vbpiper like this.
  4. Jun 24, 2019 at 8:40 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
  5. Jun 24, 2019 at 9:09 AM
    dwillhere1
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    Ok guys thanks for the input. I already have a pin that will fit but was wanting to use another along with a hitch vault that I bought. Guess I’ll return the vault. I’ve had class 1V hitches on my other vehicles and none of them this thick. Thought it was more a Toyota hitch thing.
