Trailer hitch wiring NIGHTMARE
Discussion in 'Towing' started by Jimkana, Jun 3, 2015.
  1. Jun 3, 2015 at 9:21 PM
    Jimkana
    Jimkana [OP] Active Member
    Jim
    Alaska
    06 Lifted 4x4
    6" Fabtech lift Dirt Logic 2.5s 4:88 Yukon Gears 35" Toyo MTs 18" KMC Misfits All Pro APEX leaf springs All Pro APEX bumper Custom Grillcraft grill Stainless Exaust K&N intake Wet Okole seat covers Alpine audio deck and subs Protech tool box
    I had to replace the wiring hitch on my 2006 Tacoma because the guy who had it before me must have backed into something so I wired a new one in and to the best of my knowledge it's correct. When I am connected to the trailer the lights are dim and using either turn signal makes both lights flash like the hazards are on. When I hook up to it with my girlfriends 2011 4Runner all the lights are bright, either turn signal works and the brakes light up. So it must be on my pickup but I have no idea where I went wrong. I cross checked between the wiring on my pickup and the hitch wiring instructions. I wired it as so;
    Pin 1) Green/ Tail lights
    Pin 2) Black/ Battery
    Pin 3) Red/ Left Turn Signal
    Pin 4) Yellow/ Back up lights
    Pin 5) Brown/ Right Turn Signal
    Pin 6) White/ Ground
    Pin 7) Blue/ Trailer Brakes
  2. Jun 3, 2015 at 9:24 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    The dimming sounds like a bad ground. See you sure white and black are setup correctly
  3. Jun 3, 2015 at 9:38 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Wiring sounds right, but I agree about the ground. Check your grounds, anytime I have that issue with truck/trailer, I just put a jumper from a good ground spot on the trailer to the one on the truck. Fast way to check if that's the cause.
  4. Jun 3, 2015 at 9:57 PM
    Jimkana
    Jim
    Alaska
    06 Lifted 4x4
    I also agree with the ground but I'm pretty sure it's on my pickup because when I'm hooked up to the 4Runner all is well. I briefly looked at the wires coming out of the hitch to trace down the ground wire coming out but it splits off into other harnesses and I quickly gave up. Any insight?
  5. Jun 3, 2015 at 10:09 PM
    Jimkana
    Jim
    Alaska
    06 Lifted 4x4
    I just took a minute to really think about how I have it currently and I'm pretty sure I have Pins 1 and 2, 6 and 7 reversed. I'll double check
  6. Jun 3, 2015 at 10:52 PM
    Jimkana
    Jim
    Alaska
    06 Lifted 4x4
    Yeah I had it all backwards. I think I have wiring dyslexia lol everything works now. Thanks for the input guys!
