Trailer Light Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by andrew90, Apr 14, 2015.
  1. Apr 14, 2015 at 8:18 PM
    andrew90
    andrew90 [OP] Member
    Jamestown, TN
    04 Tacoma SR5
    3" lift kit, 4.10 gears, 33" Nitto Trail Grappler Tires
    I'm having problems with my 4-pin wiring for trailers. My left turn signal and is working but nothing else. No running lights brake lights or right turn signal. I seem to have a good ground and solid connections(continuity) to the converter box in the back of the cab. Anyone have some insight on this? If I get a manual does it show wiring for the trailer system? I also can't seem to find any fuses relating to the trailer wiring.
    I have a 2004 Tacoma SR5 Double Cab.
  2. Apr 15, 2015 at 9:56 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Where did you get your trailer wiring? Tacomas (correct me if I'm wrong) have a separate bulb for the turn signal and brake light. Trailers (wired with 4-pin) share a bulb for the turn and brake. Therefore you need a converter. http://www.amazon.com/Hopkins-43315-Plug-In-Simple-1995-2004/dp/B0002Q7ZKK
    If this is what you have then please ignore this part.
    Do you have any LED lights installed in your turn, brake, or running lights? These are not compatible with most trailer converters. I put an LED specific one on my truck once I converted everything to LED. I cannot remember which on it was off the top of my head but I will see if I can find it.
  3. Apr 15, 2015 at 3:58 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  4. Apr 17, 2015 at 9:28 PM
    andrew90
    Jamestown, TN
    04 Tacoma SR5
    Thanks for the info. Sounds like this will be a good long term fix.
  5. Apr 17, 2015 at 9:33 PM
    andrew90
    Jamestown, TN
    04 Tacoma SR5
    Another question. Where is the module your referring to? From the diagram it looks as if you just splice and solder the diodes in directly behind the connector.
  6. Apr 19, 2015 at 12:07 PM
    keakar
    karl
    louisiana
    the module is something you buy to convert the Tacoma wiring to work the way trailer wiring works.
    see it here: http://www.ebay.com/itm/TRAILER-HIT...ESS-/141633556843?hash=item20fa04916b&vxp=mtr
    that black box between the trailer plug and the truck tail light plugs is the converter module
    what I did was to just remove and replace the module with the diodes
    the module is made with diodes and a transistor inside it and the transistor is what always goes bad on them. the transistor is useless and serves no purpose at all but its used like a fusible link instead. you already have fuse protection for your wiring so this transistor is just a weak point that makes the unit fail over time so you need to buy another one. it truly is built with parts designed to fail after a certain period of time so you buy another one. diodes never fail and last forever so if they built these with just diodes and no transistors in them then they would only be able to sell you one in your lifetime.
  7. Jul 13, 2024 at 12:22 PM
    dcubed
    dcubed Well-Known Member
    I know it's been nine years since this thread was live, but I like to make use of history, so I'll post my issue here. Like @keakar, I have a Hopkins 43315 module in my 03 Tacoma. I think it worked fine when I installed it several years ago, but I'm not 100% sure. I just bought a new utility trailer with wiring issues, and during the repair I found the following. When all observations were made about the trailer, all lights on the truck were working fine.
    - running lights (RLs) work fine
    - right and left directionals work fine
    - brake lights do not work (no extra brightness over RLs, no light with RLs off)
    - hazard lights do not work
    It seems very strange to me that the hazard lights don't work since each of the directional lights work independently.
    Do I have a bad (Hopkins) module? Some other issue?
    Nessal likes this.
  8. Jul 15, 2024 at 11:43 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Take a voltmeter to the truck side plug when the hazards are on and see if you are getting any voltage. If yes, then it's downstream and most likely something with the trailer. If no, then test the wires going into the module. If you got voltage there, then it's the module. Had some trailer woes a year ago and it ended up being the module.
    dcubed[QUOTED] likes this.
