Trailer Light Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by damnfingers, May 24, 2017.
  1. May 24, 2017 at 5:12 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    There should be a fuse labeled towing lights 30a and one back up LP 10a that problem is really strange. Let us know what the out come is at the dealer OP
  2. May 24, 2017 at 5:19 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. May 24, 2017 at 5:21 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Places that sell trailers and auto parts stores will usually have a tester available for use, free.
  4. May 24, 2017 at 7:48 PM
    myoldmantruck
    myoldmantruck Well-Known Member
    How would he know then that they were overheating?
  5. May 24, 2017 at 8:34 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Use a Voltmeter and the chart on post #17. Check to see if your connections are good. Might need to be cleaned in order to make a good contact.
  6. May 24, 2017 at 8:47 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I never said it was overheating. My guess is that it is a resistance based issue with all the fancy computer systems in the truck. It just sences a short and/or too much load and goes into a fail safe. Then you have to turn truck off, back on and it tries again.
    damnfingers[OP] likes this.
  7. May 24, 2017 at 9:30 PM
    myoldmantruck
    The OP said it.
  8. May 24, 2017 at 11:36 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I assume you have a bad plug on the truck end. Take it to a dealership
  9. May 25, 2017 at 5:24 AM
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Yes...
  10. May 25, 2017 at 5:26 AM
    damnfingers
    Gene
    Mississippi
    I was wondering about that...might be the cheap ass Harbor Freight meter...but both left and right blinker circuits read the same and the right side works fine.
  11. May 25, 2017 at 5:27 AM
    damnfingers
    Gene
    Mississippi
    No converter...7 pin to 7 pin.
  12. May 25, 2017 at 5:28 AM
    damnfingers
    Gene
    Mississippi
    Great idea...I'll try that this morning. Also planning on running the truck down to the trailer store down the street and see if they'll let me try to hook up to one of their trailers.
  13. May 25, 2017 at 5:31 AM
    damnfingers
    Gene
    Mississippi
    All lights on the truck work fine with the trailer NOT hooked up...when hooked up the right flasher will work but the left flasher won't...emergency blinker only works on the left side.
  14. May 25, 2017 at 5:31 AM
    damnfingers
    Gene
    Mississippi
    Taking it in for service tomorrow but not sure they'll be able to hook it up to a trailer to test.
  15. May 25, 2017 at 5:33 AM
    #35
    damnfingers
    Gene
    Mississippi
    There's not...I looked. BUT if it were a blown fuse the blinker wouldn't work with the trailer disconnected...and it does.
  16. May 25, 2017 at 5:36 AM
    #36
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Take Your trailer in with the truck for service .
  17. May 25, 2017 at 5:39 AM
    #37
    myoldmantruck
  18. May 25, 2017 at 5:44 AM
    #38
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    So you have lights on left side of trailer? The only thing that is not working is your left turn signal? I would try another light first. Than if that dosn't solve the problem work your way back from the light to the pin connector looking for a bad ground, kinked or frayed wire. Your getting power to light there is just some kind of interruption along the way.
  19. May 25, 2017 at 6:15 AM
    #39
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Some things to try if you haven't:
    Take your trailer connector apart and swap the left and right wires. See if the problem follows or stays.
    If it follows and is now on the right side then you have a wiring issue some where between the connector and light.
    If it stays then it's most likely in a light assembly or that light's ground.
  20. May 25, 2017 at 6:37 AM
    #40
    Glamisman
    Glamisman Well-Known Member
    trailer manufacturers are notorious for using scotch locks, those quick connects that you squeeze with pliers to connect. They will also use the mounting screws as the ground for the trailer lights. On my 2 enclosed trailers the rear turn/brake/running light housings are mounted on the drop down door and the grounding point is through the back door aluminum skin then through the frame then through the hinges... how long do you think that lasted? In fixing it I found 3 scotch locks per circuit. One for the 7 pin lead to trailer harness, one each for the trailer harness then one each for each trailer harness to light fixture... rear light housings, running lights to the top of the box. Not saying that your factory trailer wiring was a poorly installed as mine just something to look at. Does this explain why it works with your buddies truck, maybe, like what was said earlier, Toyota's might be "sensitive".
    damnfingers[OP] and TacoTRD78 like this.
