Trailer Light Problems
Discussion in 'Technical Chat' started by JHarrisTaco15, Apr 7, 2014.
  1. Apr 7, 2014 at 5:20 PM
    JHarrisTaco15
    JHarrisTaco15 [OP] New Member
    Jordan
    Harris
    Trux 3 inch lift, gear rims.
    I just bought a converter for trailer lights for my boat. I followed the instructions and double checked all the wiring. After I got it all hooked up I checked the plug with a meter and nothing was right. I got my dad who is a electrician to check it and he said everything was right. The problem I'm having is when you have the park lights on and you hit the brake all the lights go off. Neither of the turn signals work. According to the meter when I hit the brakes, the ground becomes hot although it is grounded to the frame. Any help would be appreciated.
  2. Apr 7, 2014 at 9:57 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Possibly a bad convertor box
  3. Apr 9, 2014 at 10:50 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Where is the meter connected when you measure the ground as being hot? The normal connection would be to have one lead connected to ground and the other to the point you are measuring. In that case the ground cannot be hot if it is wired correctly. My experience has been that most trailer lighting problems are with proper grounding.
