Trailer light problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DOGCHASER, Aug 25, 2009.
  1. Aug 25, 2009 at 2:28 PM
    DOGCHASER
    DOGCHASER [OP] Member
    07 tacoma TRD
    I have no trailer light voltage on back plug. Checked the fuse box and find no fuse just a item that could be a circuit breaker.
  2. Aug 25, 2009 at 2:29 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    check. fuse?
    make sure your lights are on before you test?
  3. Aug 25, 2009 at 2:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    x2.
  4. Aug 25, 2009 at 2:38 PM
    DOGCHASER
    07 tacoma TRD
    Am sure the lights are on.
  5. Aug 25, 2009 at 2:39 PM
    FlawedXJ
    Paul
    NorAla
    ok....and how about the fuse?
  6. Aug 25, 2009 at 2:39 PM
    DOGCHASER
    07 tacoma TRD
    Yes the lights are one. Can see the tail lights on the truck are on.
  7. Aug 25, 2009 at 2:40 PM
    DOGCHASER
    07 tacoma TRD
    Where is the fuse located? I checked the fuse box and only find a blue, relay looking item where it says trailer lights.
  8. Aug 25, 2009 at 2:41 PM
    FlawedXJ
    Paul
    NorAla
    may just have to grab the manual and look around, however, i've had times where i've jsut had to pull every fuse and look at it until i found a bad one. you'd be surprise what systems are tied together.
  9. Aug 25, 2009 at 2:44 PM
    DOGCHASER
    07 tacoma TRD
    With a tester probe I attach the clip on a good ground and touch both sides of the fuse with the probe. Tells me if it is OK or not. I simply cannot locate the fuse for the trailer tail lights.
  10. Aug 25, 2009 at 4:09 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Check for a bad ground....white wire, I think. Are your terminals clean? Clean the terms then open up the pins using a tiny screwdriver or a pocket knife. Nothing? Take a wire from the truck to the trailer to ground them together. A test light or meter is most valuable now. Start from the plug on the truck and work your way back.
    Good luck,
    Larzzzz
  11. Aug 25, 2009 at 4:15 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    OH and dont forget to check the fuses
  12. Aug 26, 2009 at 12:16 AM
    reg boulette
    reg boulette Well-Known Member
    For lack of info, am assuming you have factory pre-wired trailer light connection package? Can't say directly, but if no breaks in wiring, probably the little blue thing (under hood fuse panel) is at fault. I wired my 09 truck with T connectors at the tail lights, but using 4 way emergency flashers or connecting harness while truck was running threw the truck turn signals into a 'crash' - even though not hooked up via factory method. So some idiosyncracy exists as stated earlier, where systems tie into each other.
