Trailer lights fine until headlights turned on
Discussion in '1st Gen. Tacomas (1995-2004)' started by guinness97, Aug 13, 2022.
  1. Aug 13, 2022 at 6:04 PM
    guinness97
    guinness97 [OP] Member
    2004 Tacoma DC 4x4
    New Hopkins converter box and same problem. Trailer ights working fine until I turn the headlights. I guess I can't have running lights and brake lights.
  2. Aug 13, 2022 at 10:23 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the Forum!
    Sounds to me without really knowing the whole story .
    Your out of the Box converter does not work !! The trailer light harness is FUBAR or something is wired wrong.
    Maybe explain what your problem is and how you reached this point??
  3. Aug 14, 2022 at 7:30 AM
    guinness97
    2004 Tacoma DC 4x4
    Thanks.
    I think this is the 4th one for this truck. It came with a Reese converter when I bought it new in 2004 which I replaced with the same 2x. Figured I would try a different one this time. The one this replaced lit all three lights on the tester at once. Put the Hopkins one in and couldn't find where I put the tester so I hooked it up to the trailer and everything worked. At least I thought it did. Guess I will dig in to it.
  4. Aug 14, 2022 at 8:47 AM
    Bivouac
    Time to upgrade to a multimeter they are so more useful being able to have real numbers instead of just a light.
    Good Luck!
  5. Aug 14, 2022 at 11:10 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it may sound stupid but double check the connections (signal, power, ground) as there could be something amiss
    also what type did you get, the plug-in or the "tap-in" variety?
  6. Aug 14, 2022 at 3:15 PM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    What lights aren’t working? I had an issue a while back and everything worked but the blinkers were dim traced it back to the trucks tail light connectors being high resistance and needed some tlc. Cleaned the contacts and put some dielectric grease on them and all the lights worked and trailer harness box didn’t smoke like other ones.
  7. Aug 15, 2022 at 5:38 PM
    guinness97
    2004 Tacoma DC 4x4
    The brake/turn signals don't work when the headlights are on. Tried another controller and the test plug shows faint flickering with the headlights on. Connections look good. Used dielectric grease the last two controllers.
  8. Aug 15, 2022 at 6:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    How is your trailer ground? Alot of trailers ground through the hitch instead of the plug.
    Try taking a jumper cable and puting one end on a good ground on the truck and the other end on a good ground point on the trailer and see if they work.
  9. Aug 15, 2022 at 6:20 PM
    guinness97
    2004 Tacoma DC 4x4
    I'll try everything at this point. Trying the quick fixes first. Too hot here and I am running out of time before our wagon train heads to our new home.
  10. Aug 15, 2022 at 10:37 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    From etrailer questions about Hopkins converter
    Hi, I installed Hopkins 43315 four flat wire harness on my 1999 Tacoma and Im using 48655 four flat tester to test the system. With my headlights off, the tester shows the brake lights work and the turn signals work. When I turn on my headlights, only the tail lights work, the brake lights and turn signals stop working. The harness is cleanly and tightly grounded to the frame. Any ideas how to fix this? Thank you
    asked by: Hanna
    Expert Reply:
    What you're describing is a text book ground problem. The ground connection isn't strong enough to handle the load with the running lights on but will handle it when it's just the brake or turn signals. But you said your ground is good.
    In this case make sure the pins of the Hopkins # HM43315 are clean and corrosion free. Also check the tester, especially the ground. I'd also check the connector with a trailer instead of just a tester, or check the tester on another vehicle's 4-way. My guess is the tester isn't getting a strong enough ground connection.
    https://www.etrailer.com/question-318964.html
    Bivouac and frizzman like this.
  11. Aug 16, 2022 at 7:26 AM
    guinness97
    2004 Tacoma DC 4x4
    Thanks for the response.
    I tried the test plug on my other truck and it worked fine. Ran a wire from the neg terminal on the battery back to the trailer plug and it still does the same thing.
  12. Aug 16, 2022 at 8:06 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you try grounding it to the frame of the trailer?
  13. Aug 16, 2022 at 8:12 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I will reiterate my previous statement, check the connections at the tail lights (if you have the plug in variety) for any corrosion, frayed wires, cut wires, or loose wires.
    just because it's new does not mean it's without a possible issue. I've replaced 4 controllers in my 18 years due to them failing and the wires themselves getting corrosion internally
    Bivouac likes this.
  14. Aug 16, 2022 at 8:22 AM
    guinness97
    2004 Tacoma DC 4x4
    I hooked up the trailer and tested everything. The lights work properly. I don't know why the test plug would cause me to go through all this when the problem was the controller from 2 years ago that just went bad. Feel like a dumbass for not double checking with the trailer connected. I checked the new controller with the trailer connected after I installed it and everything worked then.
    mechanicjon likes this.
  15. Aug 16, 2022 at 8:23 AM
    Bivouac
    The thing is wiring and plugs and sockets can all be corroded that your naked eyes can not see.
    Meter probes sometimes push through the corrosion and appear to work fine.
    Given the option I will go with a 7 pin plug and add a separate turn signal light and do away with the evil converter boxes.
  16. Aug 16, 2022 at 9:44 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    myself included.
    only downside is if you need/want to tow something that is not "your" trailer that has the matching wiring configuration. you would still need the converter for that
  17. Aug 16, 2022 at 9:56 AM
    Bivouac
    Ha Ha I thought of that my work around was I built a Custom Light bar that Has a long enough cable to hang on 24' trailer. it works great.
    I got tired of Towing Welders in the Wee Hours with not having lights.
    If I used it more often I would Go Wireless.
