Trailer Mods?
Discussion in 'Garage / Workshop' started by Howen, Jan 15, 2016.
  1. Jan 15, 2016 at 7:59 AM
    Howen
    Howen [OP] Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Our winter project is to refurbish our 5 x 8 ft. garden trailer. We use it for hauling many things--furniture, firewood, mulch, gravel, etc.
    The plan is to strip off all the hardware, wiring, and boards, and then touch up any rust. I'd like to rewire it and relocate the spare tire.
    Will post some pics.
    Got any cool suggestions for customizing?
  2. Jan 15, 2016 at 9:12 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    What kind of decking does it currently have?
  3. Jan 15, 2016 at 9:13 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    LED's all around, maybe wire up a battery and outlet(s) so you can use electric tools wherever you are like a weed whacker, hedge trimmer, vacuum, etc?
    Run a trickle charger to it when parked.
    Mobtown Offroad and Howen[OP] like this.
  4. Jan 15, 2016 at 10:11 AM
    Howen
    Pressure treated lumber. Plan to replace.
  5. Jan 15, 2016 at 10:15 AM
    Howen
    We do have a solar panel on the shed. I could park the trailer by the shed and use the shed's solar system to charge the trailer. :thumbsup:
  6. Jan 16, 2016 at 3:20 PM
    Howen
    Floorboards off, hardware off, pressure washed.
  7. Jan 17, 2016 at 2:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is your trailer you know just what you use it for.
    What does it need to make using it easier for you Work more efficient??
    I would rebuild the Hubs !! New wheel bearings and seals
  8. Jan 17, 2016 at 2:34 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Kegerator. :anonymous:
    Beer is good while doing all those projects. :cheers:
  9. Jan 17, 2016 at 2:41 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I could almost agree with that now after my neighbor managed to drive through the side of my shop .
    No more Alcohol allowed on the property !!
    The scary part was he had his baby girl in the truck and just left here in there after crawling out of the mess he made and stumbling home.
    Good thing I was home and called his wife.
    As he had no clue where his truck was or how he got home or just what he had done.
    I just got finished paying off the repair of the building.
  10. Jan 25, 2016 at 7:47 PM
    Howen
    Trailer is dismembered and in the garage. Snomagedon interrupted all progress.
    No kegerator but will definitely have duel beer bottle openers and may have a cooler.
    Cheers!:cheers:
  11. Jan 30, 2016 at 10:23 AM
    Howen
    Maryland weather is warm enough today to work in the garage with a propane heater. The neighbor and I were going a little stir crazy after all the snow, so we busted out the electric router. We used a hinge router bit to recess six D-rings into the new floor boards.
  12. Jan 30, 2016 at 10:28 AM
    Howen
    Next we used a straight router bit to make a channel in the outside edge of the outer most floor boards. The channel will hold the wires for the side- and tail-lights running the length of the trailer. The original setup had these wires running in a small diameter metal pipe on top of the floorboards. That pipe was constantly getting hit with the shovel and rake when we emptied loads of mulch and rock from the trailer. We are permanently removing the pipe and putting the wires inside the boards.
  13. Jan 30, 2016 at 10:37 AM
    xjoey dubsx
    xjoey dubsx Curb Crawler
    Joe
    Cleveland, Ohio
    2015 Taco TRD Sport 6" Coil Overed
    6" PC Coil Over Lift, 35s, 18s, Extang Bed Lights, Garage Door Opener Hack, Bullydog GT Tuner, BHLM, 8300 Tinted everything else, Raptor Lights, Bakflip G2
    2" hitch mount on the front to store your ball mount. Also, you can slide a winch cradle into it to winch heavy items in it.
    Howen[OP] likes this.
  14. Feb 7, 2016 at 1:30 PM
    Howen
    Two coats of Rustoleum sure makes it look nicer. Probably will do two more coats before reassembly.
  15. Mar 15, 2016 at 7:25 PM
    Howen
    Boards back in.
    Mobtown Offroad likes this.
  16. Mar 15, 2016 at 7:33 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Feiro for the win!
    Nice job on the trailer. We did the same thing with our parts trailer. Pulled wheels off, rebuilt hubs, wire wheeled the wheels and painted, picked up a LED light kit, need to install. Going to replace floor boards. I cut the back gate off, made new pins and now the gate is removable. Going to put a 2" receiver on it for endless options.
  17. Mar 15, 2016 at 7:34 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Kind of funny, I am in MD too and did all the work in the garage with propane heater on full tilt haha. What a winter we had.
  18. Mar 15, 2016 at 7:34 PM
    Howen
    I like the removable gate idea. Thanks!
  19. Mar 15, 2016 at 7:34 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Best thing I ever did. Makes loading pallets from the rear with a fork lift a breeze.
    Howen[QUOTED][OP] likes this.
  20. Mar 15, 2016 at 8:16 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id put some kind of roll on or spray bedliner stuff on the front side of the wheel wells...something to resist rock chips...
