Trailer plug nightmare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FIREMED59, Jun 15, 2014.
  1. Jun 15, 2014 at 3:02 PM
    FIREMED59
    FIREMED59 [OP] Member
    Jake
    Clovis, CA
    08 TRD SPORT 4x4 DCLB White
    Undercover tonneau, AMP bed xtender, OME lift with Dakars
    I have a 2008 DCLB and my trailer plug is not working at all. I have checked all the fuses under the hood and dash and still nothing. I've tested every contact with the receiver and there is zero power coming to it. I've heard that there have been some mid-harness fuses on other Tacomas but have not located any on mine. Anyone else had any issues like this? I would love to not have to drop $200 on a whole new harness if that's not the issue in the first place.
  2. Jun 15, 2014 at 8:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are your tail / brake / signal lights working?
  3. Jun 15, 2014 at 8:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    There is a relay in the fuse box under the hood. Swap it with the fuel pump relay to test. Its the same relay. Make sure you put them back after you get done testing.
    You do not want to leave a weak relay in the fuel pump slot.
  4. Jun 15, 2014 at 8:56 PM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    you could possibly have a short some where. it could be a minor one that would not blow a fuse. if you have a meter you can check continuity to ground, for every wire and if it doesn't rings out you have a wire that is broken some where.
  5. Jun 15, 2014 at 8:56 PM
    koditten
    Kirk
    Central Michigan
    You do need the key in the "on" position. The plug will be dead without the key on. I'm sure you knew this, but its worth repeating.
  6. Jun 16, 2014 at 9:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Define "not working" tail lights, brake lights, turn signals,aux power or all of the above?
  7. Jun 16, 2014 at 12:48 PM
    gearcruncher
    Canadain bumper technician
  8. Jul 22, 2014 at 3:24 PM
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    Good stuff
  9. Jul 24, 2014 at 11:34 AM
    FIREMED59
    Jake
    Clovis, CA
    thanks for the replies, had not thought to check the relays. As to the questions, all the lights on the rear of my truck work fine but none of the electrical for the trailer works.
