Trailer plug relocation bracket
Discussion in 'Bay Area Metal Fabrication' started by Fractured, Jan 9, 2013.
  1. Jan 9, 2013 at 9:31 PM
    Fractured
    Fractured [OP] FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Have you guys ever thought of making a trailer plug relocation bracket for the factory hitch/ 7 pin plug?
    I'm looking for one that faces the plug towards the ground, and tucks it up under the hitch instead of right out the back- similar to this thread--- http://www.tacomaworld.com/forum/2n...diy-relocate-trailer-harness.html#post3316038 ( credit to those in the thread, I did not create this idea).
    Ive seen your work and you guys do great stuff. I would much rather spend a little on a pro quality one than make it myself! Plus you guys are right across the bay from me :cool:
  2. Jan 10, 2013 at 9:18 AM
    adanfon
    adanfon YNWA
    Adán
    Visalia, CA
    '11 Tacoma DCLB 4x4
    grillcraft, debadged, bilstein 5100's @ 0 w/ OME 886 coils and a 1/4" top plate spacer, rear has tsb springs and Wheelers HD progressive add a leaf. 1.25" spidertrax wheel spacers. Powder coated stock wheels. Tinted tails. Sport headlights. 20" led bar behind grille...
    Sub'd :popcorn:
  3. Jan 10, 2013 at 2:12 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Sure let's do it I'm sure i can whip something up :D
  4. Jan 10, 2013 at 2:12 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
  5. Jan 10, 2013 at 4:15 PM
    Scotty3
    Scotty3 Well-Known Member
    charley
    north highlands
    2011 4WD TRD Off Road
    King CO, Toyo MT's, TRD intake, TRD Short Shifter, Borla Exhaust, Road Armor Bumpers, Warn 9000XD Winch,
    Interested
  6. Jan 10, 2013 at 4:37 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Sub'd interested in this as well.
  7. Jan 10, 2013 at 5:03 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Awesome!!
  8. Jan 10, 2013 at 8:48 PM
    JLee
    Jerry
    Bay Area NorCal
    What are you doing this sunday? I'll be at the shop trussing my rear axle if you want to swing by in the afternoon.
  9. Jan 11, 2013 at 6:53 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    I might just have to do that. Let me talk to my gf.
  10. Jan 11, 2013 at 7:17 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    PM sent
  11. Jan 22, 2013 at 5:39 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    any progress on this?
  12. Jan 26, 2013 at 9:31 AM
    Camps
    Camps Well-Known Member
    Greg
    San Jose, CA
    04 DC TRD
    883s, Dakars+AAL, 285s, Sliders, BoxRocket bed rack, Custom bike rack
    Interested...
  13. Feb 6, 2013 at 6:07 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I'm in for one.
  14. Feb 6, 2013 at 6:30 AM
    JLee
    Jerry
    Bay Area NorCal
    Its kinda hard to do without the truck you will need to come up to the shop so i can take measurements.
  15. Feb 6, 2013 at 11:04 AM
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Plug location
    I somehow hit mine the other weekend, and bent the exisiting one out a ways, and also tore the plug from the holder.
    Toyota wants $256 for a new plug and $275 to install.
    For that amount would look to a new rear bumper.
    What I am going to do is replace, but move to a higher spot,
  16. Mar 5, 2013 at 6:37 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge.
    Any way 2 buy a bracket?
    Bent mine already
    Az
  17. Mar 5, 2013 at 9:08 PM
    JLee
    Jerry
    Bay Area NorCal
    I have no bracket for sale i dont have a 2nd gen at my shop to just whip one up so until someone comes to my shop i will not have one.
  18. Mar 6, 2013 at 2:32 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Benjamin
    Marysville, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I would be interested in being a test truck for this one. I destroyed mine a while ago when I was out wheeling and just haven't had time to fix it. I do need to buy a couple things from Jerry so it would be convenient for me. I wouldn't be able to head down that way until the weekend after next though.
  19. Mar 6, 2013 at 3:40 PM
    JLee
    Jerry
    Bay Area NorCal
    That works for me just let me know when and I'll let you know if I'm available.
  20. Mar 6, 2013 at 3:52 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Glad to see someone is able to get a truck over there! Looking forward to purchasing a bracket!
