Trailer Recommendations for my 2020 Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by suomiM31, Oct 31, 2021.
  1. Oct 31, 2021 at 9:34 AM
    suomiM31
    suomiM31 [OP] Well-Known Member
    Looking for a travel trailer. Must have toilet. Love to hear of recommendations/experiences. Airstream tastes, brokedick dog finances.
  2. Oct 31, 2021 at 9:38 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Determine your tow capacity. Now, divide by 2. The empty/curb/unloaded weight of the trailer should not exceed that limit.
    You need to leave room for gear, hitch, propane, food, people, dishes, pots/pans.........
    Then be focused on load distribution when you load up for a trip. Remember, the LOADED tongue weight is counted as CARGO on the truck.
    Suggest to look at the many variants of folding campers. Some folders are hard sided.
    <edit> One more thing..... Don't believe the salesmen. If his lips are moving, then he is lying. Get the numbers, do your own figuring to check the capacities.
    RustyGreen and Chew like this.
  3. Oct 31, 2021 at 9:40 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I’m at 2,500# loaded truck and trailer. Glad I don’t have more.
  4. Oct 31, 2021 at 9:41 AM
    TacoLin1234
    TacoLin1234 Well-Known Member
    Lance
    Sutherlin, OR
    2020 TRD Sport
    Lots out there to choose from. I would be looking at some of the "lightweight" versions. Also, a dual axel tows better than a single. I had a Winnebago and was easy to tow. Good luck in your findings. :)
  5. Oct 31, 2021 at 10:06 AM
    retrofive
    retrofive Well-Known Member
  6. Oct 31, 2021 at 10:13 AM
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    I am thinking about getting into the travel trailer game myself.
    I saw a Coleman Lantern LT 17B - rated at 3042 lbs dry. It's single axle, which apparently doesnt tow as easily (my understand is the wind can be a bigger factor with single axle, especially at 22ft long).
    But, it's affordable at ~$15,000. Earlier in the year, I saw them as low as $13,000 new. I am really curious about the long haul reliability of it being so cheap.
  7. Oct 31, 2021 at 10:31 AM
    suomiM31
