trailer rock protection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hanrock, Oct 23, 2016.
  1. Oct 23, 2016 at 9:10 AM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    Hello Im looking for any and all trailer rock protection ideas purchased ,homemade or otherwise Im leaning towards a homemade version of the rock tamers what ever I do will need to be transfered from truck to truck thanks
  2. Oct 23, 2016 at 9:12 AM
    Pigpen
    Dan
    Northwest Montana
    Sounds like you already have a solution.
