Trailer running lights acting up.. Help please :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sp0oN, May 3, 2016.
  1. May 3, 2016 at 1:45 PM
    Sp0oN
    Sp0oN [OP] New Member
    I got a 06 TRD sport with the tow packet. there is a problem with my wires on the truck i cant seem to figure out. My running lights will only work sometimes. Brake and signals I have no problem. is the two yellow markers in the front, side markers on top of the tires, the rear lights on the top and the rear tail light on the left that don't work. right rear tail light will work just fine. I had replaced the 7 pin connector wire harness with a new OEM and it worked for half a day. I had the trailer 4 pin connector replaced with a new one, problem continued. I hooked up a new wire harness from the tail lights to see if it would work, problem continued. all the fuses are good, I have not had any of them get blown. I had another trailer connected when it was acting up just to make sure it was not the trailer that had a wire problem, the 2nd trailer did the same thing. when ever the running lights would be turned on, only the right side back light would work, none of the other lights in the trailer would work. Keep in mind this problem is not all the time. some times they work and some times they don't. I had a voltmeter hook up to the pins to make sure it was getting current, it had between 12v and low 13v constant. I was told it could be a ground issue in the truck been that it does it with other trailers also but so far i have not found the problem.
    If anyone has an Idea of something else I can try or where to look for the problem please help.
    thank you
  2. May 3, 2016 at 2:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you had 12V to 13 V at the plug pins and the lights didn't work you have a ground problem.
  3. May 3, 2016 at 2:17 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Check the ground at the lights
  4. May 3, 2016 at 2:29 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    My 7 pin OEM plug is a piece of crap. I have to move the trailer connector around to make sure all lights work. Fortunately I have a 7 pin plug with indicator lights on it.
  5. May 3, 2016 at 5:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  6. May 3, 2016 at 5:48 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Check your ground, and NO, the ball is not a good ground, you need a ground wire. Next wiggle the crap out of your 7 pin to 4 pin adapter, those are junk and don't last real long. Yours may be making poor connection.
    I always had trouble with the standard lights and the way that the wires just push in, they are always giving me problems. I bit the bullet on my utility trailer and my boat trailer last year and went all LED, I'd did so on my boat too. Well worth the money ..... eBay is your friend for those lights.
    If you stay with standard lights, I clean the bulb terminals real good and apply dialectric grease.
  7. May 3, 2016 at 6:35 PM
    Sp0oN
    yeah my trailer already got LED tail lights only the regular running lights are not LED. how about the fact that I connected an aftermarket harness to the tail lights of the truck and it still does the same thing? I did buy a new 7 to 4 connector just to eliminate the possibility + with the direct harness there is no need to use the adapter.
    is there a way I can add an additional ground to the trailer or the connectors itself?
    Thank you again for the feedback
