Trailer towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3 Rivers Bob, Feb 27, 2022.
  1. Feb 27, 2022 at 1:29 PM
    3 Rivers Bob
    3 Rivers Bob [OP] Member
    2011 Tacoma
    Hi all. I've been towing a small boat as well as a smallish flatdeck with my 2011 Tacoma Dual Cab 4x4 with no issues. However, I just bought a travel trailer with a GVWR of 4800 lbs. so I'll be installing an oil/transmission cooler on it. I see that some people are suggesting the high output alternator as well. I'm just wondering why because I'm new at this. Thanks in advance.
  2. Feb 27, 2022 at 1:33 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    4 banger or V6? How often and how far you hauling that rig? Aerodynamic or a wind bucker? Makes difference.
  3. Feb 27, 2022 at 2:01 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Check this thread out. It will answer all of your questions
    ColoradoTJ likes this.
  4. Feb 27, 2022 at 2:03 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Assuming you have the V6 4800 lbs. is right at the practical limits of a Tacoma. I'm guessing that trailer is 3500ish dry. If I were you, I'd pack light and try to keep the weight under 4500 lbs. You'll need a brake controller for the trailer brakes too. The heavy-duty alternator is needed because you're also charging the battery in the trailer as you drive.
    The thing that is the real limiting factor with towing is your payload. There is a sticker on the driver's door jamb with a statement that
    reads, "The weight of occupants and cargo should never exceed XXXX lbs". Each truck is somewhat different, you'll just have to check yours. Mine is 1200 lbs. But some trucks are under 1000 lbs, some closer to 1500. But 1100-1200 is pretty typical for a 4X4 DC.
    You should figure about 13% of the loaded trailer weight as tongue weight. So, if loaded to 4800 lbs. you'll have 625 lbs. on the hitch. The rest is what you have for passengers and cargo in the truck. With my truck that leaves me 575 lbs. My wife and I combined weigh 360, so I'd only have about 215 lbs. for other gear in my truck. Which is cutting it pretty close. You'll just have to do the math on your truck.
    My travel trailer is almost identical in size 3425 dry and 4750 GVWR. I can pull it with my Tacoma, but it sure is a lot easier with my F150.
    gsubioguy and ScrippsRanch67 like this.
  5. Feb 27, 2022 at 2:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    3 Rivers Bob[OP] likes this.
  6. Feb 27, 2022 at 9:31 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I believe it’s because once hooked up, the truck’s alternator will charge the trailer’s battery. If you have the towing option, that should be sufficient.
  7. Feb 28, 2022 at 6:54 AM
    TnShooter
    Deogee
    STOCK
    I would worry less about the alternator and more about the ability to cool the transmission fluid.
    gsubioguy likes this.
  8. Feb 28, 2022 at 9:20 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Look into a weight distribution hitch like "EZHitch" Makes lots of difference.
  9. Mar 1, 2022 at 2:25 AM
    daniellemill
    daniellemill New Member
    Danielle
    I used an EZHitch weight distribution hitch and it worked great for me!
  10. Mar 1, 2022 at 7:34 AM
    DG92071
    DG92071 Well-Known Member
    4800 lbs is no problem with an intelligent driver. The biggest issue will be the lame stock Tacoma brakes.
  11. Mar 1, 2022 at 12:09 PM
    3 Rivers Bob
    2011 Tacoma
    V6 DC.
    V6 DC 4.0L. Plenty of info coming in. Thanks Salty.
  12. Mar 1, 2022 at 12:10 PM
    3 Rivers Bob
    2011 Tacoma
    Agreed. I intend to set up solar for the trailer electrical. Thx.
  13. Mar 1, 2022 at 12:12 PM
    3 Rivers Bob
    2011 Tacoma
    TnShooter[QUOTED] likes this.
  14. Mar 1, 2022 at 12:14 PM
    3 Rivers Bob
    2011 Tacoma
    Thanks Marshall. Great info and yes, we're running pretty parallel.
  15. Mar 1, 2022 at 12:15 PM
    3 Rivers Bob
    2011 Tacoma
    Thanks AJ. That's a ton of great info!
    AJKlug1[QUOTED] likes this.
