Trailer Towing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mcfly6667, Jun 13, 2023.
  1. Jun 13, 2023 at 9:01 AM
    Mcfly6667
    Mcfly6667 [OP] Member
    Ken
    2001 Impulse Red Tacoma 3.4 4wd SR5 TRD
    Looking into towing a small car carrier with a 2000# VW on it. Not a "tail dragger" but a full, albeit smallish carrier. Ive seen towing capacities mentioned between 2000-3500 for my 3.4 5spd I'd be near the max on this I suspect even on the high side. I've got a good hitch. Anyone run a set-up like this ? or is it a bit too much to ask of it. Ive got a 600 mile trip planned.
    The TRD gives me a little suspension help but not in the brakes dept.
  2. Jun 13, 2023 at 9:19 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I believe your total payload capacity is 5,000#. You won’t break any speed limits, but it should be ok. Towed a 12x6 enclosed trailer from Michigan to Georgia to Colorado a few years ago with my 3.4
  3. Jun 13, 2023 at 9:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You should be fine.
    Your truck is a manual, so you won’t have to worry about trans temps.
    I pulled well over 3,000lbs with my 99’ 3.4 w/Automatic
    Your truck should be just fine.
  4. Jun 14, 2023 at 1:05 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Make sure the trailer has enough tie down locations.
    Trailer brakes are a big help.
    Many Times I have come off hills in first gear never touching the brakes.
    I hate Interstates so I avoid them. I am happy driving 45 to 55mph on State Roads and US highways
  5. Jun 17, 2023 at 4:30 AM
    Kleenax
    Ray
    Michigan
    Ah yes! After reading Bivouac's response just now, I realized that I forgot to mention TRAILER BRAKES!
    Pulling that much weight, they are a MUST! And adjusted correctly, they work wonders when pulling a loaded trailer; truly a confidence-builder!
    I bought this one by Tekonsha and installed it in about an hour, and I didn't even have to adjust it!:
    https://www.trailerjacks.com/tekons...vL8W24eVJVujwkvwgYMMgByUciV8dTohoCB1AQAvD_BwE
    Bivouac likes this.
  6. Jun 17, 2023 at 9:03 AM
    Bivouac
    Here in Pa any trailers with a GVW over 3000 pounds must have trailer brakes.
    Kleenax[QUOTED] likes this.
