Trailer wireing harness question.
Discussion in 'Towing' started by Wyowill, Jan 29, 2014.
  1. Jan 29, 2014 at 5:47 PM
    Wyowill
    Wyowill [OP] Active Member
    Rolled my '05 4 cyl 4X4 into a ball and sent it the crusher. Replaced it with a 2014 access cab 4cyl.,5 speed 4X4.
    Question, is there available a factory plug and play wireing harness that has connection for trailer brake controller and 7-way trailer plug in?
    If so what is the part number?
    I would rather not cut and splice the wireing and local dealer sez "Only 4 prong harness is available"
    Thanks,
    Will
  2. Jan 30, 2014 at 2:10 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    There's been some discussion about that, somewhere if you search enough it will pop up. That's all I have . . . . .
  3. Jan 30, 2014 at 2:14 PM
    lilgreen2393
    lilgreen2393 Member
    Talmage
    Mount Holly, NC
    05 Toyota Tacoma PreRunner SR5
    NONE YET!
    As far as i know, there isn't. I've done all my wiring myself to make my trailer lights "plug and play" on my 05 Tacoma.
  4. Jan 30, 2014 at 2:17 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    everything but trailer brake controller will be plug and ply.
  5. Jan 30, 2014 at 2:26 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    You might have to go to a trailer place and pay to have a brake controller installed, and theyll get the 7 way plug on there for you too. Buy the brake controller yourself, thatll save you some money at least. Simple to install "T-connector" wiring harnesses exist but that's just to get trailer lights going with the 4 way plug. That's what I use in my 4 cylinder Tacoma.
