trailer wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willard417, Apr 9, 2010.
  1. Apr 9, 2010 at 10:31 AM
    willard417
    willard417 [OP] Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    i just put a hitch on and i'm trying to hook up the light harness does anyone know which wires go together? its not the plug in one its the one that you need to splice
  2. Apr 9, 2010 at 11:03 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    True, like said above, in the long run you will be much better off. It will be much easier as well with the plug and play, and its a cheap fix.
  3. Apr 9, 2010 at 11:24 AM
    willard417
    Luke
    beaver county, PA
    Nobody has one and I need to
    move today
  4. Apr 9, 2010 at 11:50 AM
    willard417
    Luke
    beaver county, PA
    really? nobody knows which wires are which?
  5. Apr 9, 2010 at 11:53 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    The only think I would suggest is trace the wires back from your tail light bulbs and follow the harness until you get down under the bed.
  6. Apr 9, 2010 at 12:10 PM
    Newf
    Newf Member
    Manny
    Ottawa, Canada
    08 4X4 Basic
    Before you start spicing make sure you have the extra module that converts from 5 wires on the truck to four wires on the trailer plug. As for which wires you need a drawing or someone who has one to answer that.
    Manny :):):)
