Trailer wiring issue
Discussion in 'Towing' started by frontytaco, Aug 19, 2017.
  1. Aug 19, 2017 at 3:57 PM
    frontytaco
    frontytaco [OP] New Member
    Rick
    silversky
    raised
    2016 TRD Sport
    I perused the forums in TOWING and none seem to deal with my issue. I hooked up a Tekonsha electric brake to the factory harness in the driver's wheel well. I connected the 7 pin from my trailer to the Factory tow outlet at the back. Brake unit under the dash reads "c" - connected. So far, so good! Turned on the truck's running lights...Nuthin'...AND now the brake box reads "n.c."...not connected. HUH? Any guidance here would be muchly appreciated
  2. Aug 19, 2017 at 4:07 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I always tell people to check the ground first.
    Years ago with a u-haul, I used a separate ground wire with clamps on each end, one to the frame of the truck, one to the frame of the trailer.
  3. Aug 19, 2017 at 6:08 PM
    frontytaco
    Rick
    silversky
    raised
    Thanks Killo...I circuit tested the truck outlet plug and all lines lit up when they should (as they should with factory install :)). I'm in the process of re-grounding the gnd line at the trailer plug.
  4. Aug 20, 2017 at 7:08 AM
    frontytaco
    Rick
    silversky
    raised
    So, I tried Killo's ground technique as a temporary by-pass and it worked!. After that, I ran a second line from the ground pin on the trailer 7-pin connector to the trailer frame (drilled hole, ring connector to trailer end of wire & a metal screw). taped it all up in a more permanent manner and all's well
    stickyTaco likes this.
  5. Aug 20, 2017 at 8:48 AM
    Killowatt
    Glad it worked out, I've seen it a lot.
    Years ago a co-worker made removable trailer lights for his boat, on a 2x4 so he could just leave them in the truck, and keep the lights out of the water. He asked me to take a look, he didn't even have a ground wire at all, and he worked at a power plant making electricity for over 25yrs. Taking basic electronics in high school has paid off many times over the years.
