Trailer Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by g7evans, Feb 16, 2012.
  1. Feb 16, 2012 at 9:00 AM
    g7evans
    g7evans [OP] Active Member
    Garrett
    VA
    2014 DC SB
    does anyone know where i can find the instructions to hook up a trailer wiring k+it on a 2007. i bouhgt the four-way plug kit from pep boys and it has the easy connectors. thanks
  2. Feb 16, 2012 at 9:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm assuming you bought the plug and play connectors for a flat-4 trailer connection? If so, just unscrew the tail lights, plug in each connector to the appropriate side, zip tie the wires in place and you're good to go.
  3. Feb 16, 2012 at 7:45 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You mean just the four flat plug with four wires to connect to the truck? That won't work on a Tacoma. Take it back and get a kit with a converter for the seperate signal lights on the Tacoma. It will be a box with 5 wires in and four wires out.
    I am assuming you mean those blue splice connectors, not factory style plugs?
