Trailer wiring
Discussion in 'Towing' started by 05RedTaco, Feb 26, 2012.
  1. Feb 26, 2012 at 9:02 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I bought a used trailer and the wiring harness is all fucked up... It has 4 pin harness.
    I figured the 4 pin plug on my truck has;
    - ground
    - tail lights
    - right turn signal
    - left turn signal
    The ground is connected to a bolt in a trailer so I have 3 wires left on the plug. Trailer has 4 wires. 2 wires go to each tail light. I tried connecting 2 wires to tail light wire coming out of the plug, then one wire from each tail light goes to turn signal wire. Issue is its still doesnt work properly... ugh! Doing all this with trailer connected to the hitch on my truck...
    Any help is appreciated, diagrams would be badass...
  2. Feb 26, 2012 at 9:37 AM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '24 Celestial Silver DCLB SR5
    OEM cast aluminum running boards & tonneau cover.
  3. Feb 26, 2012 at 10:35 AM
    05RedTaco
    Tony
    Scottsdale
    Thank you! +1 rep :)
