trailer wiring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma1692, Feb 20, 2016.
  1. Feb 20, 2016 at 5:36 AM
    tacoma1692
    tacoma1692 [OP] New Member
    Hey guys i have a 2016 Tacoma sr that does not have a hitch on it. I am putting a hitch on I but me and my dealer cannot find a wire harness for it. I can buy the OEM 4 pin and 7 pin plug but we are both stumped about the wire harness that plugs into the back of it. If someone could help that would be great thank you.
  2. Feb 20, 2016 at 5:44 AM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Welcome to TacomaWorld Tacoma1692.
    There are a few threads about this on the forum, but from what I know there is no connector to plug into. The towing harness option is factory installed from the front of the cab to the rear. If you ordered your Taco without it; then you would have a different harness. You will have to splice into the wiring harness in order to connect your towing equipment.
  3. Feb 20, 2016 at 5:47 AM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Take it to an RV dealer. I had a 02, same situation, they wired it all up with 4 and 7 pin connectors, and installed a brake controller.
    That was Sutton RV, Eugene Oregon. But any pro shop should be capable.
    Just an option.
  4. Feb 20, 2016 at 5:50 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. Feb 20, 2016 at 5:56 AM
    chealy86
    chealy86 Well-Known Member
    South Carolina
    2016 SR 2.7L 6spd
    Curt has a splice kit being made...its not out due to lack of parts for assembly but according to them it should be out soon.
  6. Feb 20, 2016 at 5:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Like the one I linked above? Or something else?
  7. Feb 20, 2016 at 6:42 AM
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    You probably already know this but when adding a hitch to a Tacoma without the tow package provides a towing capacity of 3,500 pounds, according to Toyota's specs. That's almost half the capacity of one with the tow package. Just something to be aware of if you plan to tow something big.
  8. Feb 20, 2016 at 7:55 AM
    chealy86
    South Carolina
    2016 SR 2.7L 6spd
    Plug and play kit.m.no splicing.
  9. Feb 20, 2016 at 7:59 AM
    TackleMeElmo
    TackleMeElmo Well-Known Member
    desch
    silverado 1500
    interested in some info from this thread...
    since you didnt order tow package, your vehicle is supposedly half as capable at towing. (3500 vs 6800)
    after you figure out an aftermarket tow package set up, can you please report back with whether or not you have difficulty towing things in the 6,000lbs range??
    please and thank you!!
  10. Feb 20, 2016 at 8:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    'Difficulty' may not be the issue. Most will never add what comes on the tow package, as it's too extensive. Trans cooler, PS cooler, high output alternator, etc. etc.
    So its the durability of the tow vehicle that will be in question if you chose to overload it. I wouldn't do it.
    I added a hitch to my 5 lug so I could use a bike rack, use a bed extender to support my yaks. No wiring needed for that of course.
    I went ahead and did the wiring, just in case I found a need to pull a small load sometime. Small flats boats, canoe trailers, small utility trailers. Things under 2500 loaded.
    TackleMeElmo[QUOTED] likes this.
  11. Feb 20, 2016 at 9:53 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    The oil cooler and the trans cooler are the biggest things. Might not have an issue over occasional light towing, but you will reduce life of the engine/trans by hauling near max loads on a frequent basis
    TackleMeElmo likes this.
  12. Feb 20, 2016 at 5:14 PM
    tacoma1692
    I was looking at the splice kit, I was hoping there was a harness that would plug and play, I have some empty plugs under my truck thats why I thought they had something. I am only towing at the most a light box trailer, I dirt bike ride with friends so I need more room than just the bed
  13. Feb 21, 2016 at 6:19 PM
    tacoma1692
