Trailex 84180 (2000lbs), 3400lb car w/ a '17 tacoma trd pro?
Discussion in 'Towing' started by M3the01, May 27, 2020.
  1. May 27, 2020 at 12:59 PM
    M3the01
    M3the01 [OP] Active Member
    Lair
    Thoughts on this, it is a lower profile trailer, 5500lbs, i know i can tow 6800lbs but im looking for real world feedback.
    Please lmk ur thoughts.
  2. May 27, 2020 at 1:16 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Get a brake controller if you don't have one. There are detailed 3rd gen threads on brake controllers. There's also a large thread on towing where you can see all sorts of light and heavy trailers being towed through various terrain.
    The truck can safely do it if you can.
