Trailhunter & TRD skid plate damage
Discussion in '4th Gen. Tacomas (2024+)' started by Jacob06, Feb 17, 2025.
  1. Feb 17, 2025 at 11:35 AM
    Jacob06
    Jacob06 [OP] Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    Has anyone that has either of these skid plates actually had a chance to bash it on some rocks?
    Both of those skids look really neat, I'm just curious how they hold up to being used.
    If you did bash it, did it show any damage? Do you have any pics?
    Debating buying one of these vs a CBI or some other traditional skid manufacturer. And between the silver powder coat and intricate stamping of the Yota stuff, I'm a little concerned.
    I had an SOS Concepts 3/16 steel plate on my 2nd gen and thoroughly bashed it many times and it showed no damage what so ever, just scratches that I'd spray over with black rusty metal primer
  2. Feb 17, 2025 at 2:25 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    I haven’t had a chance to bash on mine yet but I doubt they will take any serious beating..the one on my trailhunter is not that thick and sure most aftermarket ones would be a better fit for the ones doing serious rock crawling
  3. Feb 17, 2025 at 2:40 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Pro skid plate is aluminum, TH is steel. TH is I believe 6lb heavier but also may be slightly longer, so not very thick. Unless you are hard core the aluminum should be good enough. Plus it won't rust. Of course, you'll have to pay more to get the skid plate with three red letters.
    GrrrMaker likes this.
  4. Feb 17, 2025 at 4:24 PM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    I’m pretty sure any factory skid is gonna crumble like a pull tab… Especially on these new Toyotas. The pro or TH may be thicker but they are not as thick as aftermarket options
  5. Feb 18, 2025 at 1:12 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    Yes!
    TRD plate is 1/4" aluminum which is what most aftermarket aluminum plates are, but the trailhunter plate is 1/8" and most aftermarket steel plates are 3/16".
    This is why I was asking if anyone had actually bashed one on some rocks.
    None of these bros really wheel!?
  6. Feb 18, 2025 at 1:59 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    If you really, really wheel you would be in a different vehicle. You aren't going up chocolate thunder with these. Get whatever cranks your tractor. It will be OK.
    LN13, Btcomcast, Vidman and 1 other person like this.
  7. Feb 18, 2025 at 6:29 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I've got a Trailhunter skid plate. It's a beast. I was going to cut out a hole to access my Fumoto valve, but the steel is hardened.
    I'll be challenged to ding it.
    DRAWN likes this.
