Trailhunter vs. TRD OR
Discussion in '4th Gen. Tacomas (2024+)' started by Myhikingboots, May 6, 2025.
  1. May 7, 2025 at 4:19 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Digging deeper, you are correct...
    I confused the 2, its the Pro series rock rails that are mounted to the body, just behind the pinch seam that are pretty much worthless & non protective at all....
    That being said, the factory TH isnt that much better, VERY low profile compared to the more robust / stout aftermarket options available....
    Looking at the pics of your "rock sliders"
    no kick out
    the brackets between the 2 rails are chinsy at best, the center holes aren't helping...
    all the aftermarket brands are using tubular construction there, way more robust & durable...
    Also the mounting points are nothing special compared to other options..
    Not a fan of the low profile design, tucked tight to the body, doesnt give much side panel protection...
    I personally wouldnt pay the money for either TH or Pro rock rails, but thats me...
  2. May 7, 2025 at 4:59 AM
    Bitflogger
    Bitflogger Well-Known Member
    2024 TRD OR long bed
    I can't decide what's right for you but there are tools out there to spot incoming vehicles available, and I'm happy I delayed gratification and got exactly what I wanted. That time allowed more test rides and thoughts on what to get.
    For what I valued and know plus confirmed with testing, the halo models are less ideal for street and road use, and even as someone off road a lot, TRD OR is plenty fine. Payload capacity and weight were in consideration here. It's all good so figure out what is best for you.
  3. May 7, 2025 at 5:38 AM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Glad you did. Now I don't have to ask!
  4. May 7, 2025 at 7:34 AM
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    So you don’t own a Trailhunter and hadn’t even seen what you’re opining about. Got it.
    1Strailhunter likes this.
  5. May 7, 2025 at 8:05 AM
    slater
    San Diego
    Ive seen plenty along with Pros also...
    Crawled all through them, under them, etc...
    Even took pics of underside of one & posted on here cuz a member didnt know how to take his off & was too lazy to crawl under his own truck & take a look, use his brain...
    Just slept since then & brain farted over the lame sliders on the TH vs the lame rock rails on the Pro....
    Not judging, you want a factory one stock truck, so be it....
    Ide rather spend my money elsewhere, the OP is asking for our opinions...
    My opinion is the same regardless of the model or the type of protection...
    End of the day, its what youre getting for the COST....
  6. May 7, 2025 at 9:12 AM
    1Strailhunter
    1Strailhunter Active Member
    Florida
    2025 Tacoma Trailhunter Bronze oxide
    To each their own, this platform only out about a year and this TH with bolt of frame rock sliders straight from factory with warranty haven't fail anyone yet, or report of failure by anyone that i heard of, so anything else is just opinions. I'm sure your views is considered by the OP and helpful for this thread and others looking at after market upgrades.
