trani oil change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chano87, Jan 13, 2011.
  1. Jan 13, 2011 at 1:06 PM
    chano87
    chano87 [OP] Member
    i have an 03 taco prerunner v6 does anybody know how to change the trany fluid i found the nut at the bottom but i donk know weather to fill it up from where the dip stick is or is there a different location i dont check it vey often but i did today and it looks a little dirty so i figure i should change it never have and it has 106000 ml
  2. Jan 13, 2011 at 1:13 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    i would pull the pan and replace the filter with that mileage...
  3. Jan 13, 2011 at 1:33 PM
    chano87
    chano87 [OP] Member
    ok but do i add the trani fluid to the pan or do i poor it throught the dip stick hole should i go to the dealer ship for the filter.
  4. Jan 13, 2011 at 1:36 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    i would get an OEM filter myself.and yes, you fill it through the dipstick.not sure how many quarts you will need,maybe somebody will chime in with the info.
  5. Jan 13, 2011 at 1:40 PM
    chano87
    chano87 [OP] Member
    im on the phone with the dealer and they cant find that it needs a filter wtf i dont want to buy duralst i
  6. Jan 13, 2011 at 1:42 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    OEM part # is 3533060030
  7. Jan 13, 2011 at 1:45 PM
    chano87
    chano87 [OP] Member
    they said that the filter is a reusable i just have to clean it with an alcahol base cleaner rinse with water and let dry and place ban in trani
  8. Jan 13, 2011 at 1:49 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    if you want to do that then its ok.
  9. Jan 13, 2011 at 1:51 PM
    chano87
    chano87 [OP] Member
    thanx for the help and is this something that some one can do or should i take it in
  10. Jan 13, 2011 at 1:53 PM
    chano87
    chano87 [OP] Member
    what about the differential fluid do you know if i can change it or do i need to take that in and is there a filter there.
  11. Jan 13, 2011 at 1:58 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    its not really hard to do,you just need to make sure you have everything you need before you start.
  12. Jan 13, 2011 at 2:03 PM
    ChewbacaTW
    ChewbacaTW My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    yeah the service manual says that the filter doesn't need to be replaced.
