Tranny cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynlan1819, Apr 27, 2017.
  1. Apr 27, 2017 at 7:37 AM
    lynlan1819
    lynlan1819 [OP] Well-Known Member
    Tacoma
    Lifted
    Is it worth the hassle too put a remote transmission cooler on a 2006 DBLC 4.0 trd,in order too avoid any red milkshake problems,I live in a very hot climate during the summer ( Las Vegas).
  2. Apr 27, 2017 at 7:52 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  3. Apr 27, 2017 at 7:59 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    1. Have you physically verified your truck doesnt have one installed? Does your truck have a tow package? (you may already have a transmission cooler installed)
    2. Do you tow or carry loads in high temperatures?
  4. Apr 27, 2017 at 8:12 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I think it's worth it for the peace of mind
  5. Apr 27, 2017 at 9:02 AM
    lynlan1819
    Tacoma
    Lifted
    Anybody
    Yes I have the tow package,and it looks like a cooler is also installed,BUT it also looks like the lines are still routed through the radiator too me as it has the 2 lines going in-n-out of the left side of the radiator.
  6. Apr 27, 2017 at 9:04 AM
    dually
    dually Low and slow
    That is how nearly every manufacturer does it. Trans>Rad cooler>external cooler>trans. I think you'll be just fine, unless you're towing borderline max loads regularly.
  7. Apr 27, 2017 at 9:06 AM
    lynlan1819
    Tacoma
    Lifted
    I don't tow anything.
    But doesnt that still put you at the risk of pink milkshake.
  8. Apr 27, 2017 at 9:14 AM
    dually
    dually Low and slow
    Why would it? You're not putting any additional stress on the vehicle that would otherwise compromise the quality and lifespan of the fluid. The factory cooler is more than capable to handle the base load.
  9. Apr 27, 2017 at 9:21 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    If you arent towing dont see the benefit.
  10. Apr 27, 2017 at 9:30 AM
    lynlan1819
    Tacoma
    Lifted
    I worry about the failure of the tranny cooling tank inside the radiator due too the truck being 11 years old.Don't know if anybody has ever had one fail.
  11. Apr 27, 2017 at 9:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    that was more of a 1st gen problem, and even then it wasnt that prevalent.
    As long as you keep fresh coolant in your truck you will be fine.
