Tranny fluid check takes hours?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doug C, Jul 13, 2016.
  1. Jul 13, 2016 at 7:10 AM
    Doug C
    Doug C [OP] Member
    Doug
    2016 Tacoma Texas Edition SR5, Blazing Blue Pearl
    I went into the dealership yesterday and asked them to check the auto tranny fluid because I was experiencing some "clunking" when shifting. They said I would have to leave it for a couple of days because checking the transmission fluid levels "Takes several hours".
    Does that sound right to you? I want to check with the real experts before crying BS!
    moe2o4 likes this.
  2. Jul 13, 2016 at 7:11 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    They have to let the fluid cool like overnight and check it first thing in the morning cause they can't check it when its hot!
    ChadsPride likes this.
  3. Jul 13, 2016 at 7:16 AM
    SteenosMT
    SteenosMT Well-Known Member
    Justin
    2022 TRD Off Road
    Stock for now.
    If you didn't make an appointment with the dealer, you're probably waiting in line. I made an appointment with my dealer for my 5k mile service and they were done in less than an hour... A couple days sounds ludicrous...
    ChadsPride and kahanabob like this.
  4. Jul 13, 2016 at 7:18 AM
    Doug C
    Doug C [OP] Member
    Doug
    No, I had an appointment, but they said they didn't realize I wanted a tranny oil check.
  5. Jul 13, 2016 at 7:21 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Sounds like they maybe don't wanna do it.
  6. Jul 13, 2016 at 7:22 AM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    if you take it fist thing in the morning they will beable to check fluid level by end of day if the ambient temp is reasonable
    kahanabob likes this.
  7. Jul 13, 2016 at 7:23 AM
    Doug C
    Doug C [OP] Member
    Doug
    Yeah, I'm pretty sure they don't! When I asked about the U-joint lube he tried to tell me that they don't have grease zerks on them any more. I honestly haven't looked, but from the posts here it seems that they do.
  8. Jul 13, 2016 at 7:24 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    The fluid has to be in a certain temperature range. On my old Tundra it was between 115-133. So it may have to cool down a little which could take a couple hours depending on how hot it is.
  9. Jul 13, 2016 at 7:25 AM
    Doug C
    Doug C [OP] Member
    Doug
    It's hot in Texas this time of year, so I may have to leave it over night like they said based on your and moe2o4's posts.
    Bob259 likes this.
  10. Jul 13, 2016 at 7:25 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This. Tranny fluid expands like nuts when hot. They have to let it get down to about 114F before they can check the level. This can take several hours if your fluid is up to operating temperature.
    Doug C[OP] and moe2o4[QUOTED] like this.
  11. Jul 13, 2016 at 7:34 AM
    odinsbro15
    Eric
    LOS ANGELES CA
    i believe the inspection temp (fluid temp) needs to be 108 or below
    PackCon likes this.
  12. Jul 13, 2016 at 7:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    This.
    They should have just rescheduled you for a drop off prior to closing, an early AM diagnosics/service, and a mid morning to noon pickup.
    Simple, if someone you are dealing with will just think a little.
  13. Jul 13, 2016 at 7:42 AM
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    When the dealer's tech checked mine he asked that I leave my truck overnight...it was 1 qt. low and the ECU was reset (3K miles). Learned about this issue as well as the protruding rear door seals on TW. Both were corrected without a hassle from the dealership and so far...so good (6K miles).
  14. Jul 13, 2016 at 7:43 AM
    Mother
    Mother Well-Known Member
    Orlando
    2016 DCSB OR 4X4
    Posted 6,427,822 times already. Fluid has to cool and be brought back up to temp to check it properly.
    Searching is the shiznitter. You can learn so much.
  15. Jul 13, 2016 at 8:04 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    An independent shop did a drain and fill on mine in an hour and a half. It shifts great. If they would put a dipstick back in these trucks it could eliminate a lot of grief on checks.
    Clearwater Bill likes this.
  16. Jul 13, 2016 at 8:11 AM
    Mother
    Orlando
    2016 DCSB OR 4X4
    Nope. Everyone would be checking the fluid at different temps and then panicking when they thought they found it was over filled or under filled. We'd probably get even more useless transmission threads than we are now, if that's possible.
    paranoid56 and kahanabob like this.
  17. Jul 13, 2016 at 8:15 AM
    PackCon
    Connor
    That is an excellent point.
  18. Jul 13, 2016 at 8:20 AM
    Shelf Life
    Rob
    Central Oregon
    I never had a problem checking the fluid on my '95 4Runner, or any other auto with a dipstick. I just followed the manuals instructions and always checked it at operating temp. I did add fluid sparingly though, then checked it again later.
    SilvFx and Clearwater Bill like this.
  19. Jul 13, 2016 at 8:26 AM
    morri89
    morri89 Well-Known Member
    Brendan
    Hopedale MA
    2020 Rubicon
    Yes, but not everyone is as sensible or logical as you. People would just be checking it and not referring to the manual.
    kahanabob and Mother like this.
  20. Jul 13, 2016 at 8:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    Disagree. Many folks are reluctant to open the hood and check it at all. Even if it's shifting funny and they read about it here. They'll just take it to the dealer anyway. Not that there is anything wrong with that.
    But it would make the turnaround time faster for the owner, and make the mechanic's life simpler.
    And for those of us who are reasonable DIY'rs, and have been using dipsticks correctly all of our driving lives, we can at least keep an eye on things. Some of us tend to hold on to vehicles past warranty. Or buy them after it's already gone.
    I'm grateful my little 4 banger has a dipstick equipped trans.
    #dipsticksmatter
    Shelf Life likes this.
