tranny fluid check?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brutalguyracing, Nov 12, 2009.
  1. Nov 12, 2009 at 8:50 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    how do you check the tranny fluild?? 09 tacoma 4.0??????
  2. Nov 12, 2009 at 8:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    You don't. They are sealed trannys that only need service at 100k miles.
  3. Nov 12, 2009 at 9:29 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    There isn't a dipstick to check, but a specific procedure and an overflow plug on the bottom. Procedure must be followed preciously to obtain the correct level. Simply pulling the overflow plug without the engine running will result in a loss of fluid.
    I'm curious to hear where this "sealed" designation came from? Why would something with more holes than the previous generation be deemed sealed?:confused:
  4. Nov 12, 2009 at 10:40 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    just got off the phone with the service dept.SHE told me u dont EVER need to change your auto. tranny fluid because it has (world standard) fluid.i said the book tells u at a 100,000 your to do it.SHE said its up to me if i want it done.but SHE would wait till way after a 100,000 to do it.she had to look up the price cause they dont do many there.$261 dollars for that service.im torn between getting it done now.only have 80,000 on it but i tow and haul shit.giong to investigate this more.got a old school buddy that works for toyota/lexus,see if i can pick his brain.
  5. Nov 12, 2009 at 11:05 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you should change your trans fluid at every 30k interval, i change mine every 15k.if you drain and fill, it will only take 3 quarts.AFTER DRAINING,fill to the top of the fill hole,start engine and fill till fluid is level with the bottum of the fill hole.remember,GREASE AND OIL IS A WHOLE LOT CHEAPER THAN MACHINERY..............good luck.
  6. Nov 12, 2009 at 3:51 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks guys.... how times have changed.....
  7. Nov 12, 2009 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have heard of ALOT of people having issues with their trannys after doing it this way. There is a pretty strict proceedure to drain and fill. Temp has to be a certain temp, and it must be filled until it comes out of the "Check" hole in the bottom. As well as run thru the gears in a certain manner.
  8. Nov 12, 2009 at 4:09 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Maybe I'm missing something here, but the only mention of replacement of automatic transmission fluid I see according to the maintenance schedule is at 120,000 miles, and this is under items for special operating conditions...driving while towing.
  9. Nov 12, 2009 at 4:12 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    The owners manual states that under normal conditions the transmission fluid does not have to be changed. if you look in the scheduled maintenance book "special conditions" are defined as driving on dusty roads, towing, or in areas of high heat. i do all of the above so i will be getting mine changed at 15,000
  10. Nov 12, 2009 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you sure thats for the Automatic, and not the Manual?
  11. Nov 12, 2009 at 4:19 PM
    rhodehard09
    tampa, fl
    I'd rather pay to have it changed than to have to argue with some tool at the dealear about getting a tranny swap
  12. Nov 12, 2009 at 4:20 PM
    rhodehard09
    tampa, fl
    I'm pretty sure. i dont have the book in front of me though
  13. Nov 12, 2009 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Well mine says 15K for the manual, and 100K for the auto....
  14. Nov 12, 2009 at 4:23 PM
    rhodehard09
    tampa, fl
    I just edited that post left out the key word not.
    Sorry chris4x4
  15. Nov 12, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worries, I was just wondering if there was a discrepancy in manuals or something. Changing the fluid in the auto early, surely wont hurt anything, but all the doccumentation I can dig up puts the service interval at 100k. Im running mine to 100k and Im gonna do some oil samples, and such.
  16. Nov 12, 2009 at 4:34 PM
    rhodehard09
    tampa, fl
    im a little ocd when it comes to my truck.
  17. Nov 12, 2009 at 4:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nothing wrong with that. :)
  18. Feb 17, 2010 at 10:11 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    The World Service trans fluid is hard to find except at a Toyota dealership of course
