Tranny fluid on 99 PreRunner
Discussion in 'Technical Chat' started by red1210, Sep 16, 2009.
  1. Sep 16, 2009 at 8:47 AM
    red1210
    red1210 [OP] Member
    99 PreRunner
    Quick scenario: Loaned my brother my truck for a a few years. Told him to keep up on the regular maintenance, he didn't. The truck now has 160k miles on it. The transmission was replaced due to a factory defect at 40k miles......so the tranny has approx. 120k miles on the same fluid. Same for the differential fluid as well.
    I found out nothing had been changed and told him to go immediately to a shop and get it flushed and filled. He called a shop and they said they wouldn't change tranny fluid that old. They said the truck would be sure to start leaking and probably begin slipping within 20k miles or so.
    I asked a few of my mechanic buddies and they said the same thing. for some reason I have never heard of this before. Is this true or does Toyota have a different procedure/schedule for tranny fluid? Can I just do a drain and fill rather than a flush? My buddies told me to just leave it alone.
  2. Sep 16, 2009 at 8:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Drain and Fill would be a good thing. Bad oil is always BAD for a vehicle. Doing a drain and fill isnt gonna replace all the fluid, so, do a drain and fill, give it a week, and do it again.
    Welcome to TW! :)
  3. Sep 16, 2009 at 8:52 AM
    red1210
    red1210 [OP] Member
    99 PreRunner
    I see. I take it I don't have one of the newer sealed trannys???
  4. Sep 16, 2009 at 8:52 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What Chris said. I have never heard of what you are bieng told (leaking). Perhaps you could call around and see if other shops say the same thing?
  5. Sep 16, 2009 at 8:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, you don't.
  6. Sep 16, 2009 at 9:02 AM
    red1210
    red1210 [OP] Member
    99 PreRunner
    Any special tools needed to fill it?? Special nozzle/funnel??
  7. Sep 16, 2009 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A small one. You need to fill via the dip stick tube.
  8. Sep 16, 2009 at 9:08 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    one thing you have to think about with transmission fluid that hasnt been changed in that length of time.....sometimes, not in all cases, but sometimes, draining the old fluid and putting new fluid in may cause the tranny to slip gears some,until its mixed with the rest of the old oil. doing a flush when it has gone this long can potentially burn the tranny up, cause its used to the old fluid with all the metals in it, and removing them can clean the gears and valve body and such too much. just a heads up.
  9. Sep 16, 2009 at 9:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    A funnel is definitely a good thing. Find one that will fit in the tube and still allow you to get the ATF jug in there.
  10. Sep 16, 2009 at 9:08 AM
    red1210
    red1210 [OP] Member
    99 PreRunner
    Go to dealer for fluid or is mine one of the off the shelf fluid years??
  11. Sep 16, 2009 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good info, Will. SO...Do you think he should leave it?
  12. Sep 16, 2009 at 9:10 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    x2 :popcorn:
  13. Sep 16, 2009 at 9:11 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well man, with 120k miles, myself.....i'd be kinda hesitant about it, but then again, the toyota trannys are built alot better than most dodge and chevy trannys,as well as fords too, do it MAY be ok to do.
  14. Sep 16, 2009 at 9:13 AM
    red1210
    red1210 [OP] Member
    99 PreRunner
    This is essentially what I was told by a few people. and some of them acted like it was a sure thing it was going to happen........so TM06, do you think 2 drain and fills would be OK. Or would I still experience the same problems as if I flushed it with a machine??
  15. Sep 16, 2009 at 9:16 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly man....i have seen quite a few transmissions slip like hell and then lose all the gears after their fluid was changed....moreso when it was flushed,but i have seen it a couple times when it was just a drain/refill. its totally your call, but i'd hate totell you nothing would happen then your tranny go out.
  16. Sep 16, 2009 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Will...Thats why I suggested to drain and fill first. That will only replace a few quarts, then do it again. Thing is, if nothing is done, the tranny life is being compromised.
  17. Sep 16, 2009 at 9:21 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I am inclined to agree Chris.
  18. Sep 16, 2009 at 9:44 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on the phone with him now........and i agree also. as long as he doesnt flush the system, and does a couple of drain/refills....first one drop the pan and clean the pan and filter also,he should be good to go.
