Tranny Fluid To Help Clean Engine?
Discussion in '4 Cylinder' started by Shorty Bang, Jan 21, 2010.
  1. Jan 21, 2010 at 12:29 PM
    Shorty Bang
    Shorty Bang [OP] Member
    Tennessee
    2.7 4X4
    Nuttin
    My local grease monkey told me to help clean my engine (140K+ Miles), use 1q of tranny fluid in place of 1q of oil.....he found when replacing my timing chain I had alot of "sludge" in the engine. Has anyone heard of this type of cleaning? Will it hurt anything?
  2. Jan 21, 2010 at 2:29 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    I would advise not doing that. Use a quality oil and change every 3000 miles. I have herd from an older guy to use tranny fluid in the gas tank helps clean it but I am not doing that either.
  3. Jan 21, 2010 at 2:36 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  4. Jan 21, 2010 at 2:53 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Just use a quality synthetic oil and it'll clean the sludge out after a few oil changes. Might end up with some leaks if the sludge is the only thing keeping old gaskets from leaking.
  5. Jan 21, 2010 at 4:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    A quality oil or synth oil will clean your engine.
  6. Jan 21, 2010 at 4:59 PM
    BWro
    BWro Well-Known Member
    Tranny fluid is a detergent that will help clean a engine
  7. Jan 21, 2010 at 5:15 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    ATF is a high detergent oil. Viscosity about 10w. I used it on my old used beaters with great results. Shorten oil change interval to 2000m. Use DEXRON atf only. DO NOT USE ANY TYPE F FLUID IN THE ENGINE!
  8. Jan 21, 2010 at 5:20 PM
    jandrews
    '09 FourDubDee TRD OR
    If it was meant to be put in the engine it would be called engine fluid.
    Oddly enough, there's this product out there called engine oil...
    As others have stated, increase your frequency of changes and use a synthetic. She'll clean up in a few changes.
  9. Jan 21, 2010 at 5:28 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i used atf in my 4.3L s10 pickup. atf is full of detergents that help clean the engine and also free up sticky lifters. midway between changes i would drain about a liter of oil and top it up with atf. gives the engine a good flushing over those last few thousand km before changing the oil. it wont hurt anything.
  10. Jan 21, 2010 at 5:37 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    If it isn't any good, the only thing bad that could happen is you'd harm the engine.
    That's all........
  11. Jan 24, 2010 at 7:39 AM
    Shorty Bang
    Tennessee
    2.7 4X4
    Nuttin
    4yea-5nea
    Thanks guys
  12. Jan 24, 2010 at 7:57 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I heard about doing that to, but I wouldn't do it. Maybe just use seafoam changeing the plugs after this is a must and just keep on using syn. oil.
