tranny fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Apr 4, 2011.
  1. Apr 4, 2011 at 6:28 AM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    mich
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    called the dealer today too get a price on toyota oem atf. he told me that they use valoline max life atf in there shop now? from the searches i have done on this site, i didn't see valoline as a dealer choice. it may be here, i might have not seen it! dealership said i could use in my taco and the fjc as well.
  2. Apr 4, 2011 at 7:08 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Find another dealer!
  3. Apr 4, 2011 at 7:10 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the 02 tacomas use a dex/merc transmission fluid.......not the t4 toyota fluid. so im pretty sure you'd be safe using the valvoline maxlife oil. its a good oil anyway.
  4. Apr 4, 2011 at 1:51 PM
    ChavisT93
    ChavisT93 Well-Known Member
    Lexington, SC
    07 reg cab base
    That doesnt suprise me. You will be fine using maxlife in both of your vehicles. I use it in my 03 which specs T-IV. From the Valvoline website....
    Recommended for use where the following fluids are specified:
    Ford MERCON®, MERCON® V, MERCON® SP and LV
    GM DEXRON, DEXRON II, III and VI
    Toyota and Lexus Type T, T-III, T-IV and WS
    Allison TES 389
    Nissan Matic-D, Matic-J and Matic-K
    Honda and Acura ATF Z-1 (except CVT)
    Mercedes NAG-1
    Mitsubishi Diamond SP-II and SP-III
    Kia SP-II and SP-III
  5. Feb 5, 2012 at 11:59 AM
    dbrosnan2009
    dbrosnan2009 Member
    Dan
    NewBern NC
    04 tacoma 2wd
    not a one
    anyproblem with mixing .... 2 quarts of toyota-IV with another brand? I only bought 3 quarts of T-IV and realize I am low after a drain and fill. To get more toyota ATF I will have to drive 20 miles. I can get to autozone in less than a mile.
  6. Feb 5, 2012 at 12:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can mix it without any problems. the valvoline multi foreign vehicle fluid they have at autozone is compatible.
  7. Feb 5, 2012 at 12:03 PM
    dbrosnan2009
    dbrosnan2009 Member
    Dan
    NewBern NC
    04 tacoma 2wd
    not a one
    Thanks tacoman .... I was worried I messed up. I see in the other post you said 4 quarts .... thanks again.
  8. Feb 5, 2012 at 12:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man.
  9. Feb 6, 2012 at 4:11 PM
    02YOTA33
    02YOTA33 Well-Known Member
    Matthew
    North Carolina
    02 SR5 TRD TACOMA
    10% tint, Clear corners, AFE pro dry s, Blackedout badges, 5704 Viper alarm/remote start, Sockmonkey decals, Flowmaster 50 series, 3" Toytec ultimate lift 16" 7069 pro comp wheels 285/75R16 BFG AT K/O
    TRANSMAX HIGH MILEAGE
    CASTROL TRANSMAX HIGH MILEAGE IS FOR USE IN MOST TRANSMISSIONS WITH OVER 75,000 MILES.
    Specially formulated for maximum transmission life in high mileage vehicles
    Additional seal conditioners help stop leaks
    Extra cleaning agents reduce varnish and deposit formation
    Protects against clutch wear and restores smooth shifting
    Newer cars will also benefit from Castrol Transmax High Mileage
    Can be used in many vehicles including those that require:
    Ford MERCON® V (and prior)
    Chrysler ATF+3® (and prior)
    GM 2005 models and prior (not for use where DEXRON®-VI is required)
    Honda - ATF-Z1
    Hyundai
    Nissan - Matic-D, Matic-J, Matic-K
    Toyota - Type T, T-III, T-IV
    For a full list of applications, see the Product Data Sheet below.
    Can I use this in my 02? It calls for dexll or dexlll. Just want to make sure before I drain and fill. Thanks guys.
    I am here: http://maps.google.com/maps?ll=35.540993,-78.487178
  10. Feb 6, 2012 at 4:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you "should" be ok with that.
  11. Feb 6, 2012 at 4:47 PM
    02YOTA33
    Matthew
    North Carolina
    02 SR5 TRD TACOMA
  12. Feb 6, 2012 at 9:00 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I run the valvoline max life in my '04 and its mixed with whatever was in there before I bought the truck. Mixed since you cant really drain all of your atf. No issues after 20ish thousand miles.
