Tranny fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Feb 29, 2012.
  1. Feb 29, 2012 at 8:09 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Any alt tranny fluid or should I stick to Toyota OEM?
  2. Feb 29, 2012 at 11:30 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I went with Amsoil universal ATF and haven't had any problems. Be warned, it is not cheap.
  3. Feb 29, 2012 at 12:50 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    From Walmart. Was like $20 and 10k miles without an issue.
    "Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 295 and 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required."
  4. Feb 29, 2012 at 12:52 PM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    Been running OEM since I got my truck 9 years ago. Changed every 30k. No problems at all.
  5. Feb 29, 2012 at 4:10 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    I run whatever autozone or orileys dex III they have.
  6. Feb 29, 2012 at 7:34 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Redline is top notch. I run the MT-90 version in my Manual, smooth as butter!
