Tranny Flush at 176k+ miles? Experience, thoughts, "anecdotal facts" requested.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jon M, Sep 3, 2020.
  1. Sep 3, 2020 at 9:23 AM
    Jon M
    Jon M [OP] Well-Known Member
    SE Minnesota
    09 Tacoma SR5 TRD Sport w / Towing Pkg
    2009 V6 Automatic. I bought it brand new with 14 miles on it.
    About 16k miles ago, I had a local shop do a drain and fill on the tranny. The tranny had never been serviced in anyway prior to that.
    Lately, I've been thinking about taking it to the stealership for a flush and fill. I'm thinking this because I don't want to do repeated drains and fills and I'm not sure what that shop used. I'm not DIYing this (...probably).
    Anyway, the age old debate of doing a flush on an old tranny is weighing on my mind. Now that many of our trucks are considered old now, have any of you done a flush and fill on your tranny or have general thoughts about the "debate" of doing it at all.
    Thanks.
    OldManTacoFeels likes this.
  2. Sep 3, 2020 at 9:35 AM
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    I’m about to do it but mainly because I use my truck for work in Seattle and there’s a lot of shifting and hard starts etc due to the hills and traffic
  3. Sep 3, 2020 at 9:45 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My truck had 129K on it when I bought it and I wasn't sure if the transmission was ever serviced. My dealer has a BG fluid exchange machine so at almost 141K I had it done. Shifting slightly improved in the lower gears, but I still get the occasional harsh shift into OD. Its always done that, but I'm not exactly easy on my truck, especially with the hilly and mountainous terrain around here. Would I do it again, hard to say. Truck is almost at 144K now, I'll probably do it again at 200K if the frame makes it that far.
    racerX969 and BillsSR5 like this.
  4. Sep 3, 2020 at 9:48 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    We have the BG flush machine at the GM dealer I work at. It does a great job. Well, except yesterday when a valve failed and it shot atf all over the shop. Oops
    BillsSR5 likes this.
  5. Sep 3, 2020 at 10:06 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Dealer did mine at 115k 4 years ago and shifted better and could feel the torque converter lock up (more positive than before) so I was/am happy with the results.
    I towed a 6000lb trailer then a 3500 boat so it was a smart thing to do. Coming up on 165k so will do it again in the next year. Lots of opinions out there so your choice, but replacing old used fluid for all new in my view can only help.
    spitdog and OldManTacoFeels like this.
  6. Sep 3, 2020 at 10:21 AM
    Powered Parachute
    Powered Parachute Well-Known Member
    Olympic Peninsula Washington State
    2014 V6 4L Manual DCSB TRD Sport
    Fab Fours rear bumper. Bestop. Uni Filter Clamp-On Breather. Scratched up and dinged mod.
    Would you do it more frequently if you had a manual tacoma.
  7. Sep 3, 2020 at 10:38 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I did have a manual 2008 and when I changed the fluid at about 50k it looked new. However, it was so easy to do myself, I didn’t care.
  8. Sep 3, 2020 at 10:41 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Subbing, I have a 2010 automatic 4 cylinder with 113K. Thinking it's about time..no issues of any kind, and of course I want to keep it that way.
    Is it better to drain/fill or flush/fill? I'd probably use an independent trans shop but I've done business there since the early 90s so I know it would be done right
  9. Sep 3, 2020 at 10:46 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    This has been discussed on this forum countless times. You will receive 3 answers:
    - Never change fluid
    - Only do pan drains
    - Flush entire system
    So which story are you going to believe?
  10. Sep 3, 2020 at 10:51 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    some people never change their trans fluid for the whole life of the vehicle so.
  11. Sep 3, 2020 at 11:00 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    #1 buy yourself 13 quarts of OEM T-IV ATF,#2 buy yourself a replacement OEM Toyota crush washer #3 get out of bed at 7am sharp drain the ATF pan with the engine COLD #4 get a measuring device graduated in quarts/ounces at the cookware dept. at DOLLAR general. #5 measure out the COLD ATF you've just drained #6 replace the plug in the pan and use the OLD gasket! #7 replace exact amount to the ounce with genuine Toyota T-IV ATF and pour it into the tube with the AT dipstick is with a nice skinny funnel you can get at Walmart #8 take truck on highway get up to operating temp. and at high speed as to lock up the torque convertor. #9 now do this procedure 2 more days in a row every morning with the ATF COLD! at your 3rd and last drain and refill replace the old gasket with a new Toyota OEM crush washer and torque it no more than 15 ft/pds! and now Grasshopper you have completely new ATF with no mess.
    Rick's 2012 likes this.
  12. Sep 3, 2020 at 11:04 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Why does no one ever talk about changing the filter inside the transmission while they're at it?!?!
  13. Sep 3, 2020 at 11:15 AM
    mngBC
    mngBC Member
    Bruce
    '09 4x4 trd off road access cab
    None
    My '09 has 176000 km on it, the Toyota dealer did mine yesterday. They call it a fluid exchange ,it's not a flush, they end up using 12 litres. I had to go out if town to have it done, not every dealer can do it.
    It's hard to put a finger on it , but it felt really good. Like new???
  14. Sep 3, 2020 at 11:25 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I know a coworker with an 07 4Runner with 200,000 miles on it. Original tranny fluid and gear oils. I don’t recommend this, but it runs perfect.
  15. Sep 3, 2020 at 11:28 AM
    Lester Lugnut
    This has also been discussed in multiple threads. Many will say the filter is just screen mesh and it can be washed out. I would like to know how many of these people have actually looked at the OEM filter for the 4.0L truck and realized that it is impossible to know with certainty that washing it out gets all of the gunk out of the filter.
    If you are going to service the filter - replace it.
    TheDevilYouLove and NAAC3TACO like this.
  16. Sep 3, 2020 at 12:07 PM
    Jon M
    SE Minnesota
    Agreed; but I'm also interested in what people have actually done and what their results were/are.
    Rick's 2012 and igno1tus like this.
  17. Sep 3, 2020 at 3:05 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    2007 4.0 5sp auto tranny and with 120k on the clock and I just recently had a drain and fill done and my trans is a lot smoother shifting . Will def do a drain and fill again .
    there is a post on here where you pump out the old fluid thru one of your trans lines, I’d do that before a flush and fill . Just my opinion
  18. Sep 3, 2020 at 3:15 PM
    igno1tus
    I’m sure everything has been discussed on this forum a hundred times , the guy just wants current opinions , if you don’t have anything constructive to add be gone
    Rick's 2012 and gasgasman like this.
  19. Sep 3, 2020 at 3:25 PM
    Lester Lugnut
    Current = Previous - I listed all 3 above. Nothing changes.
    Take a hike yourself.
  20. Sep 3, 2020 at 3:26 PM
    igno1tus
    Like I said who cares if it has been discussed , if that was everyone’s thinking there would be no posts
