Tranny Flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by bajaracer, Nov 20, 2008.
  1. Nov 20, 2008 at 10:06 AM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    06 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES,285/70/17 BFG'S AT KO'S MOTO METALS 17X8 3" REVTEK, SOUND SYSTEM
    Have any of you guys taken your tacoma to get a tranny flush some where besides the dealer? Any positive/negative side effects? Thanks
  2. Nov 20, 2008 at 10:23 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    do you have an auto??
  3. Nov 20, 2008 at 10:25 AM
    bajaracer
    Charly
    Chandler
  4. Nov 20, 2008 at 10:26 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    ow sorry i have manuals i always do it myself:)
  5. Nov 20, 2008 at 11:02 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    if you can do it your self it is cheaper.
    Here is what you do.
    if you have a drain plug, just open it up let everything out.
    THen fill it backup. Do this every oil change.
    if you need to drop the pan then do that, but only replace or clean the filter once.
    But do it every oil change for 4 oil changes.
    Then do a drian fill every 15k and you will be set for life.
    unless you tow allot, then do it more often..
  6. Nov 20, 2008 at 12:57 PM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    I took my old suburban to Valvoline and had it flushed. I felt better having somebody with all the tools to flush it and just do it once and be done. Seemed to work great. No Negetives.
  7. Nov 20, 2008 at 1:08 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    To properly FLUSH it you're gonna need to drop the pan and drain the torque converter. Add some tranny flush first, I've never tried it but I've heard Seafoam works well. Run it with the flush in for a while (RTFM), then completely empty it, change the filter, and refill.
  8. Nov 20, 2008 at 2:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im getting mine done pretty soon at my buddys shop. they have a machine that pulls all the old fluid out, then fill with new fluid. i dropped my pan a couple of months ago and cleaned the filter, and added 5 quarts of new fluid, so when i get my flush done, it should be in pretty good shape. im waiting til i install my auxiliary tranny cooler though.
  9. Nov 22, 2008 at 8:02 AM
    HerNameIsLucy
    RIP Lucy.
  10. Nov 28, 2008 at 9:31 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    i do them myself with the machine. it costs alot i think around $250. its only worth it if you really need it and havent changed your fluid for a while. but if you maintain it all you need is a drain and fill. and the filter whenever how long toyota says to do it.
  11. Nov 28, 2008 at 9:35 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Check the dealers website for coupons. I found a coupon at my dealer for $50 for a transmission service.
