tranny grinds going into 3rd gear
Discussion in 'X-Runners' started by ayesijuan, Dec 31, 2013.
  1. Dec 31, 2013 at 11:30 AM
    ayesijuan
    ayesijuan [OP] Active Member
    Cedar Park, Tx
    06 X-runner w/custom ratfink shifter
    Has customized ratfink shifter knob with flames and matches blue paint
    Has anyone had this problem before? What is the cause? It doesn't do it all of the time but when I shift at 3k or higher it does it.
    Thanks,
    Ayesijuan:mad:
  2. Jan 1, 2014 at 6:20 AM
    Tacoma Mike
    Southern Maine
    If your not having any other related issues your not informing us of then the most logical conclusion is you are starting to lose your third gear syncro.
    I will only get worse as time goes on.
    You didn't mention about extended or aftermarket warr. so i assume not.
    Myself, the first thing i would do is a fluid change if you have not done this yet. It's a simple/cheap thing to try and may help the situation.
    Some have reported chunkiness and other shifting issues and doing a fluid replacement improved the situation.
    It's a big repair job regardless.
    I can't remember if the shop has ever had to replace a taco std. trans yet.
    I know I have never had to tear one down for ext. warr.
  3. Jan 2, 2014 at 6:07 AM
    ayesijuan
    Cedar Park, Tx
    The good thing (i hope) is that I have a life time warranty on eng. and tranny when I bought it @ 97K miles, it has 125K now but I don't know if just the synchro going out would cover it or if it has to totally fail. I have to check my records, but I think I had the tranny fluid changed about a year ago but I don't know if the put the correct fluid in, I have heard it is suppose to be Redline, is this true?
  4. Jan 2, 2014 at 2:06 PM
    Tacoma Mike
    Southern Maine
    Redline is a brand name. Any oil of factory spec would work.
    You will need to get it looked at and see what they say. A total failure would be un-shiftable. It will be in their hands how they handle it. They may say drive it longer but make darn sure you know the warr. And the limitations. Get it in writing... Outside warr. Contracts are a pita. I deal with them a lot and it's NEVER, EVER smooth......
  5. Jan 2, 2014 at 6:56 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Use oem recommended fluid. Using aftermarket fluid will forever changes the coefficient of friction, which can never be undone. If it grinds only in that gear, your synchronizer assembly is probably worn out. It happens.
  6. Jan 3, 2014 at 6:20 AM
    ayesijuan
    Cedar Park, Tx
    Haha! I thought I was the only one that used "pita". Thanks for the help.
  7. Jan 3, 2014 at 2:05 PM
    Tacoma Mike
    Southern Maine
    He'll no. And I use it very often....:goingcrazy:
  8. Jan 4, 2014 at 9:37 PM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    Its been happening since 05. Toyota doesn't seem to know how to fix the problem. Google "3rd gear grind toyota tacoma"
  9. Jan 4, 2014 at 9:48 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Chuck your carpet floor mats and get weathertech liners. Then slide your seat up one more click. The carpet floor mats sometimes keep the clutch pedal from going all the way to the floor. When I got weathertech floor liners I trimmed the driver's side a little bit because it looked like the clutch pedal could catch on it. You could also change your transmission oil to a synthetic GL-4 oil like Redline MT90 or Amsoil manual transmission 75W-90.
  10. Jan 5, 2014 at 8:26 PM
    Spoonman
    Jamie
    Alberta
    That may explain a grind into every gear, not just 3rd though.
  11. Jan 6, 2014 at 6:39 AM
    ayesijuan
    Cedar Park, Tx
    Yeah, and I call them either hemmoroids or upgrade them to syphilus depending on degree of pain they are! haha!:cheers:
  12. Jan 12, 2014 at 3:39 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I need that warranty!
    Good luck with whatever is wrong, hoping its covered or not too expensive... I'd agree with synchro tho.
  13. Jan 13, 2014 at 11:46 AM
    ayesijuan
    Cedar Park, Tx
    Yeah, not only was I lucky to even find an X-Runner (and in blue) around Austin but the dealer is a Dodge dealership and this is their Warranty on any used car under 100k miles as long as you own it. Kewl!
    I am going to look around for the paperwork or call them and get back as to just how good it really is.
  14. Jan 17, 2014 at 7:32 PM
    Mountain girl
    Mountain girl Member
    Duvall Washinton
    2012 toyota tacoma 4x4
    I have an 2012 Toyota Tacoma reg cab. It sounds and feels like the tranny slips In 4th gear when I power up a hill Took it to the service dept. the guys like you have to run your RPMs higher! Is that true???? It slips in 5th also.
  15. Jan 17, 2014 at 7:34 PM
    Mountain girl
    Duvall Washinton
    It only has 9200 miles on it!!
  16. Jan 18, 2014 at 3:26 AM
    Tacoma Mike
    Southern Maine
    If it is slipping, IT'S SLIPPING.
    If you lug the engine down and accelerate, the engine should NEVER override the clutch.
    Take it back and show them again. The clutches stink in these trucks.
    He's just trying to have you eliminate the torque.
  17. May 21, 2014 at 9:04 AM
    ayesijuan
    Cedar Park, Tx
    Now I have a new twist, when I have driven about 15-20 minutes it stops grinding then after it sits for awhile it does it again for 15-20 minutes. Do you think they didn't put enough tranny oil when they did the service?
  18. May 21, 2014 at 10:06 AM
    gearcruncher
    Canadain bumper technician
    As far as I can tell , this looks like an end play issue causing the input shaft to move too much which would cause the 3rd synchronizer to possibly stick .
  19. Jan 5, 2016 at 8:02 AM
    ayesijuan
    Cedar Park, Tx
    Okay, I know it's been a long time but I finally took it in cuz the tranny started grinding everytime I put it in 3rd. I called the Dodge dealership and they sent me to the Toyota dealer and they wanted to replace the tranny but had to call the warranty people first. They came out and said they would find a used one and it would be under warranty too so I said okay. They also covered the drive which had a leaky seal and the only fix is to replace the whole drive shaft, go figure. On top of that I got the dealer to throw in the new shifter tip ball cuz it was real sloppy plus they added my short shifter kit I had been waiting to put in until after I got the grinding problem fixed. Kewl Huh?
    The only problem I have now is the tranny must not be to old as it is hard to get into reverse. I forgot how tough it was cuz I have been driving it with the sloppy shifter for so long but it is starting to ease up some.
